07-31-2012, 04:46 PM | #1 |
Rock Stacker Join Date: Jul 2012 Location: nor cal
| gearbox mystery piece
when i built my wraith the instructions showed a piece #ax80051 in the gearbox build and i couldnt find that bit anywhere so i left it out.Does anyone know what this bit does?my truck runs great without it
07-31-2012, 04:52 PM | #2 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
Pic?
07-31-2012, 04:56 PM | #3 |
| Re: gearbox mystery piece
i cant post a pic of the piece i dont have it and its located inside the gearbox but its in the instruction book during the gearbox build
07-31-2012, 05:00 PM | #4 |
Pebble Pounder Join Date: Apr 2010 Location: Guam
AX80051 is the Dig transmission case according to Axial's parts list. If your running good without it then you shouldn't worry. Last edited by sixhundred71; 07-31-2012 at 05:03 PM. |
07-31-2012, 05:02 PM | #5 |
07-31-2012, 05:05 PM | #6 |
Here... I'll do it for you... Jesus. I assume you mean AX80051-8 cuz if you are running without the tranny case, all your gears would fall out. It's a little spacer to keep the motor plate flush. Might wanna fix it. |
07-31-2012, 05:06 PM | #7 |
holy cow that number is used for both case halves,the little dig block of thing,the input shaft spacer and a few other bits
07-31-2012, 05:07 PM | #8 |
It's used for an entire pars tree. Look at the black numbers next to the part #..... I give up on this thread. |
07-31-2012, 05:11 PM | #9 |
no its the bit in the lower most gear in step 19.the case halves are ax80051-2 that spacer is -8 like you said but the bit im talking about is just ax80051 and it goes between ax30437 the gear and ax30435. not sure where wife put cam or id post a pic im sorry thought u ment a pic of the part
07-31-2012, 05:13 PM | #10 |
| I see. It's another spacer I believe. If your bottom gear breaks, you can always just upgrade to an RRP one piece anyway! |
07-31-2012, 05:20 PM | #11 |
thank you for the patience and that is the bit i was asking about.It doesnt have a additional number.I left it out and the truck runs well,i was just wondering if anyone else had this issue
07-31-2012, 05:35 PM | #12 |
07-31-2012, 06:59 PM | #13 | |
| Re: gearbox mystery piece Quote:
Updated:AX30793 Dig upgrade shipped. -- Turning Radius Measurements Posted. | |
gearbox mystery piece - Similar Threads | ||||
Mystery Giveaways? | Duuuuuuuude | Chit Chat | 58 | 12-23-2011 10:04 PM |
mystery machine? | madtinner | 1.9 Scale Rigs | 4 | 11-18-2011 08:20 PM |
Build up of Axial; Kit or piece by piece? | Patrinos | Newbie General | 5 | 04-29-2010 09:52 AM |
Mystery surging? | Chuki | General Crawlers | 7 | 03-05-2006 03:44 PM |
