08-10-2012, 11:28 AM | #1 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Curious transmission ? ? ?
I have not found this being discussed. I am in the process of a Wraith build "PHANTASMAGORIA" by DRV KRAWLER . I originaly was going to do a VP dig and have now changed direction. I purchased a C.I. 4340 steel; 5mm - Axial Transmission Outputs to compensate for the factory transmission length difference ( Outputs due to factory dig configuration ). I am building the Transmission off of the VP AX/SCX housing. Using all RRP gears. I wish to use the MIP #11116 Spline center CVD kit ( MIP Spline Center CVD™ Kit, Axial Wraith ). Has anyone else tried this ? Did it keep the drive shafts at a proper length for durable operation ?
08-10-2012, 02:46 PM | #2 |
| Re: Curious transmission ? ? ?
Sounds like a solid setup. I don't think you will have any issues with that. The extended rear output should put the shafts right where they need to be.
08-10-2012, 05:36 PM | #3 | |
| Re: Curious transmission ? ? ? Quote:
Thank you Harley ! I was really hoping for a response from you especially . I thought it would work but, without the product in hand. | |
Curious transmission ? ? ? - Similar Threads | ||||
Just Curious | BrianP | Chit Chat | 33 | 02-21-2010 04:38 AM |
just curious | usa1man | Chit Chat | 0 | 02-01-2009 01:40 AM |
