09-23-2014, 08:38 AM | #21 |
Pebble Pounder Join Date: Jan 2014 Location: Rochester
| Re: Knuckle weights for wraith?
Okay I dove in and ordered the Vanquish stage one upgrade, includes knuckles, c-hubs, and rear "lockouts"? So what do you recommend for weights to order from RCBros? I will watch the video again to see if you mention the weights you purchased. I can't wait until this little upgrade arrives.
09-23-2014, 09:10 AM | #22 |
Another option is to use my knuckles. Anywhere from bigger to MONSTER bearings Anywhere from the light version Delrin to 7075 or Brass to add weight Longer steering arms for more steering strength and less servo failures Threaded holes for super simple steering stops Possible to run the OFNA outer stub shaft for an unbreakable and unbendable stub Dlux custom knuckles V2! |
09-24-2014, 01:20 AM | #23 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Second the Dlux knucks. Love both sets I've been fortunate enough to have. |
03-10-2015, 12:14 PM | #24 |
Pebble Pounder Join Date: Aug 2014 Location: King George, VA
Bumping an older thread, because I'm in need of some knuckle weights and this thread has a lot of valuable info. My AX10 (Ridgecrest) has the same knuckles as a Wraith, only my truck has GPM aluminum knuckles. From what I'm reading, I can't use the RC Bros. setup. If that's the case, what options do I have? |
03-10-2015, 02:46 PM | #25 |
Pebble Pounder Join Date: Jul 2011 Location: Germany
Load your frontwheels?
Knuckle weights for wraith? - Similar Threads | ||||
Knuckle Weights Designed for Wraith VP Knuckles | spankbomb | Axial Wraith | 5 | 07-24-2012 11:00 AM |
VP Knuckle weights fit wraith knuckles??? | Rig Rocker | Axial Wraith | 10 | 03-02-2012 10:19 AM |
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
