09-03-2012, 10:04 PM | #1 |
Pebble Pounder Join Date: May 2012 Location: California
| Knuckle weights for wraith?
Anyone out there have knuckle weights for he Wraith?
09-03-2012, 10:16 PM | #2 |
| Re: Knuckle weights for wraith? There are a couple people who make them for VP wraith knuckles. They are a simple plate that bolts to the unused arm area. Then you bolt brass to that. I can't remember the name though. Just search, the XR section would be an easy place to find it. Lots of us are using Wraith knuckles.
09-03-2012, 10:22 PM | #3 | |
| Re: Knuckle weights for wraith? Quote:
For other options you can look at vp xr knuckle weights if you are not opposed to running xr knuckles. Or check out Blue Monkey rc, they have weights that work on xr and wraith knuckles | |
09-03-2012, 10:48 PM | #4 |
Thanks folks, does the xr Knuckles work on the wraith? And does the Xr Vp weights work on the Vp wraith knuckles?
09-03-2012, 10:58 PM | #5 |
The VP weights for the XR will not work on the Wraith knuckles due to the difference in steering arm configurations between the XR and Wraith knuckles.
09-04-2012, 06:47 AM | #6 |
Newbie Join Date: Dec 2011 Location: Falling Waters,WV
Blue monkey rc makes them just for it plus they have for other brands also
10-05-2013, 11:10 AM | #7 |
Newbie Join Date: Aug 2013 Location: Dublin
Sorry to revive a dead thread but does anyone know if someone makes a knuckle weight system for the wraith with integy knuckles?
10-05-2013, 11:17 AM | #8 |
Check RCBros in the vendor section. |
10-05-2013, 11:24 AM | #9 |
DlUx can also modify his current XR KW system to fit the VP Wraith knuckles. I run them on my sporty, and if you favor a heavy KW setup, this is the way to go as the base KW is about the same as 2 full fat rings of the RcBros design, but since it sits over the knuckle flush to the back of the hex, you can still add more rings to really get the bias and CG down and forward.
10-05-2013, 12:40 PM | #10 |
I've been using the RCBro's system on my PSC Wraith. Nice little setup. |
10-05-2013, 01:02 PM | #11 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
I have two sets of rcbros knuckle weight systems. One on my comp xr and the other on my wraith. They simple and easy to use. Great price also |
10-05-2013, 07:41 PM | #12 |
So I'll take it as a no for a set of knuckle weights that will fit Integy knuckles. lol
10-05-2013, 09:19 PM | #13 |
why not do a dinky steering and and some weight to axle that way
10-07-2013, 09:16 AM | #14 |
| Re: Knuckle weights for wraith? |
09-21-2014, 03:19 PM | #15 |
Pebble Pounder Join Date: Jan 2014 Location: Rochester
Do the RCBros knuckle weight holders bolt onto the stock plastic wraith knuckles?
09-21-2014, 03:22 PM | #16 | |
There is a possibility that you could make some spacers to raise up the mount in the front to work, but it would only mount on one side. | |
09-21-2014, 07:21 PM | #17 |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
Does anyone make some to work with the VP scale knuckles?
09-21-2014, 08:22 PM | #18 |
This Kit? Vanquish VPS06511 Stage One Kit or will the other RCbros the RBKW100 work on the stock plastic Wraith knuckle? The RBKW100 has only one tab on it to attach it to the knuckle. Also if I do spend the extra cash on the Vanquish knuckles what are the advantages to the upgrade other than being able to weight the knuckles? Just curious. Nice video by the way. |
09-21-2014, 08:32 PM | #19 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
Blue monkey offers a kit that fits axial plastic and aluminum knuckles. I have there kit for vanquish knuckles on my wraith. Very nice products.
09-22-2014, 06:44 AM | #20 |
Found a nice video on the Vanquish site explaining the knuckles and C-hubs. Not sure yet if I will get the stage one kit, or just the knuckles. My main goal is to add the weight to the knuckles and take the weight out of my wheels.
Knuckle weights for wraith? - Similar Threads | ||||
Knuckle Weights Designed for Wraith VP Knuckles | spankbomb | Axial Wraith | 5 | 07-24-2012 11:00 AM |
VP Knuckle weights fit wraith knuckles??? | Rig Rocker | Axial Wraith | 10 | 03-02-2012 10:19 AM |
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
