09-30-2012, 06:32 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Alberta canada
| So, what kind of power will a wraith axle handle?
I'm thinking of a project involving a 6s mamba monster set up on a 40 series paddle, but I have been out of the loop for a while and have no idea what parts are available for the axles? Just kind of curious if anyone has tried putting some serious power through these axles yet. Thanks, -Matt Last edited by Slowkrawl; 09-30-2012 at 06:57 PM. |
09-30-2012, 06:39 PM | #2 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| Re: So, what kind of power with a wraith axle handle?
if you're going with 6s you need to build your own complete vanquish axles
09-30-2012, 06:57 PM | #3 |
| Re: So, what kind of power with a wraith axle handle? |
09-30-2012, 07:02 PM | #4 |
09-30-2012, 08:44 PM | #5 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
| Re: So, what kind of power will a wraith axle handle?
Went to a hill climb event this weekend and most of the guys running wraiths were using pro 4 motors on 4s and they were pretty damned fast! It looked like most were running the plastic housings, however there was still lots of gear carnage!
09-30-2012, 09:47 PM | #6 |
That'd be fun to watch, get vid It'd have to be a pretty built up drivetrain, 1/8 monster trucks have trouble with that kinda combo (been there, done that). Take it down to 4s and a 540/550 motor, as was mentioned, and it'll be more fun than worrying about when your junk is gonna blow. |
10-01-2012, 05:30 AM | #7 |
| Re: So, what kind of power will a wraith axle handle? Well I do have a slash 4x4 with the 2400kv 4 pole castle set up on 3s, and it is pretty stupid lol. It might not be too bad in a bigger truck on 4s. We're they eating diff's or trannies? I will probably run a summit trans.
10-01-2012, 09:06 AM | #8 |
Also, do the wraith diffs use the same gears as the ax-10's? Looking to run over drive gears.
10-01-2012, 09:20 AM | #9 |
10-01-2012, 10:12 AM | #10 |
Thanks for the info guys!
10-08-2012, 10:59 PM | #11 |
Rock Stacker Join Date: May 2012 Location: fortaleza
| Re: So, what kind of power will a wraith axle handle? an advice, i dont know if anyone has done it yet, but the hole idea it will be to buy a tube with the inner side of the axle and the outer side of the plastic axle, then drilled a bit of the plastic axle to fit the steel tube inside the plastic axle and the axle inside the steel tube that will reenforce as hell the axle and it will prevent from binds of the axle or cracks of the axle since it will be reenforced from the outside with the wall of the inner steel tube. chears cravo |
10-08-2012, 11:27 PM | #12 |
No matter how you build them, Wraith axles won't hold that power. Just not going to happen find a more appropriate base or use a realistic power combo.
So, what kind of power will a wraith axle handle? - Similar Threads | ||||
Can't Handle The AXLE SLOP Any LONGER! | Grouper | Axial SCX-10 | 7 | 12-28-2011 08:36 PM |
How Much Power Can TLT's Handle? | crazyorigin | General Crawlers | 0 | 12-04-2009 07:08 PM |
how much power can a pede really handle?? | slobin3d | Non Crawler RC's | 9 | 02-19-2007 10:26 AM |
can clod axle handle Moab XL eh??? | JAKEF150FX4 | Tamiya Clod Buster | 18 | 12-13-2005 07:12 PM |
