10-13-2012, 05:26 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: Victoria
| Rtr wraith drag brake setting?
Can anyone tell me what the stock ae-2 drag brake setting is on the rtr wraith? It hardly works and I'm wondering if its set low as a default.
10-13-2012, 05:44 PM | #2 |
Pebble Pounder Join Date: Feb 2012 Location: Lower Mainland, BC, Canada
| Re: Rtr wraith drag brake setting?
I've read it's supposed to be fairly high, 100% IIRC, but mine wasn't 100% when I finally got the castle link to check it. I think it was only 50%. BUT, I didn't know at the time that the stock motor is quite weak, so it may not be the drag brake's 'fault', if you know what I mean. HTH! |
10-13-2012, 06:07 PM | #3 |
Yeah, I was wondering if it was because of the motor.i have a 35t I can put in but I like the speed with the 20 turn, so I'm hoping its just the settings.
10-13-2012, 08:36 PM | #4 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
When I connected a stock AE-2 to Castle Link i'm pretty sure the drag brake was only at 50%. That being said, the drag brake has a lot of variables that affect it's performance, all the way to the brushes and their springs. If you set your drag brake to 100% and it still seems lacking, you can replace the motor with a higher quality but still quick motor and the drag brake effect should increase. |
10-13-2012, 09:32 PM | #5 |
Ok, I'll try and get a hold of a castle link and test is out. The motor is brand new so it should have some holding power still.
10-13-2012, 11:10 PM | #6 |
I was able to manually program it and now it's at 100%. Must be 50% from factory.
05-23-2014, 03:42 AM | #7 |
Pebble Pounder Join Date: Mar 2014 Location: U4IA Oregon
| Re: Rtr wraith drag brake setting? |
Rtr wraith drag brake setting? - Similar Threads | ||||
Castle / AE-2 Drag Brake and Brake Power | ik632 | Electronics | 0 | 04-08-2012 07:47 AM |
Any RTR ESC's have lipo cutoff and drag brake? | Rig Rocker | Electronics | 3 | 12-31-2010 02:26 PM |
scx10 honcho no need for DRAG BRAKE?... already has drag... | yellowpasta2000 | Axial SCX-10 | 21 | 01-23-2010 09:28 AM |
does this have a drag brake setting??? | Sinastir | Newbie General | 10 | 11-30-2008 10:41 AM |
Throttle / Drag Brake / Brake Question | phatchantz | Newbie General | 5 | 05-19-2008 11:57 AM |
