10-18-2012, 11:25 AM | #1 |
Rock Stacker Join Date: Jun 2012 Location: Cincinnati
| Fitting XR Wheels
So I have bought a set of MotoWorx Aluminum wheels for my XR and decided to give the stock XR wheels to the wraith. Problem is they rub the steering linkage on the inside of the wheel. I tried shaving the wheel down a smudge but with the way I have my linkage on one side it's not going to work. I've been looking into the Junfac wideners but I think an extra 1/2 inch on each side is a bit much I only need a few mm to fit the xr wheels. I found these and they look like they would work. Anyone used them or see any reason they wouldn't work. They add 3mm to each side over the stock hex hubs. Price can't be beat either. I know the Topcad isn't top shelf equip but these are pretty simple. Axial Wraith Aluminum Hex Wheel Hub / 3mm wider Red TopCad 23024 |
10-18-2012, 11:32 AM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: Fitting XR Wheels
Should work? You couldn't just trim the steering arm a little?
10-18-2012, 12:01 PM | #3 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
I did the Vanquish SLW hub mod to my XR10 wheels that I use on my wraith. I use to use junfac wheel wideners to make them work but they where kind of sloppy.
10-18-2012, 12:25 PM | #4 |
Quarry Creeper Join Date: Jun 2008 Location: the White House
The Topcad hexes have reports of loose fitting. HPI makes hexes in various widths,try searching Fleabay.
Fitting XR Wheels - Similar Threads | ||||
Fitting 2.2s on a Dingo | Tbone | Axial SCX-10 | 1 | 09-16-2012 12:26 PM |
Fitting a body!!! HELP | Lexar | Paint and Body | 2 | 12-07-2010 07:52 AM |
fitting a brake servo | klampykixx | Newbie General | 10 | 06-26-2010 03:59 AM |
12T pinion not fitting | Kera | HPI Wheely King | 22 | 07-14-2008 06:11 PM |
Body fitting tubers | a69baldone | General Crawlers | 6 | 12-11-2007 03:22 PM |
