10-22-2012, 08:33 AM | #21 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Re: HD Differential gears binding.
id try to find countersunk M3 screws for the ring gear~ and are you using the Axial wraith center driveshafts? it may be pushing the pinion up against the ringear! |
10-22-2012, 10:34 AM | #22 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: HD Differential gears binding. I guess I have been lucky with my ring gear screws being cap heads. They came in a kit I got from Hexcrews.com guys. I was a test kit so they had no idea what kind of screws worked where. I am a little bummed being the prototyper...lol Oh well someone has to! |
10-22-2012, 10:40 PM | #23 |
Pebble Pounder Join Date: Jun 2011 Location: Sonoma, Ca
Thank you everybody who helped me on this, the reason it was binding was because of the heads on the screws that the HR lockers come with. easiest solution for me was the cutting down extra screws that are used to hold down the diff cover diff cover.
10-22-2012, 10:43 PM | #24 |
Glad you got it fixed!! |
10-23-2012, 12:19 AM | #25 |
Pebble Pounder Join Date: Nov 2011 Location: Livermore, Ca
Good to hear the issue has been solved, I was starting to worry for a second . "Thumbsup"
10-02-2018, 01:38 PM | #26 | |
Newbie Join Date: Oct 2016 Location: U.K.
| Re: HD Differential gears binding. Quote:
I just fitted an ssd wide axle to my yeti I also brought two overdrive rc4wd diff gears. On set binds on almost a complete turn the other is completely fine. There is about a mm worth of adjustment on the rc4wd pinion and in the stock I can only see room to shim the pinion closer to the crown. Edit you shim the pinion closer and away from the crown to get the whole length of the tooth to mesh. You want to shim the crown closer or away from the pinion to adjust mesh. It’s been 20 years since I learnt this but never need to put it to practice since live axles had been replaced by fwd and independent rear. so I might be a little wrong or very wrong Last edited by Rubber tutti; 10-02-2018 at 01:51 PM. | |
10-02-2018, 02:40 PM | #27 |
I had this same issue when I installed Incision diff lockers with new HD Axial ring and pinions. As mentioned above, the gasket was the culprit. Remove the gasket between the ring gear and locker and you should be good to go.
HD Differential gears binding. - Similar Threads | ||||
Differential Gears | tecboy | Axial AX-10 Scorpion | 12 | 02-06-2010 11:15 AM |
Differential gears for a SCX-10 | shambrick | Axial SCX-10 | 10 | 12-12-2009 04:09 PM |
Metal or alloy tranny and differential gears??? | illz302 | HPI Wheely King | 3 | 08-20-2009 03:24 AM |
