10-29-2012, 07:26 AM | #1 |
Rock Stacker Join Date: Sep 2012 Location: here
| shock problem
Hi, I guess this may be a general shock issue -- if so, please move to correct forum. I am rebuilding my shocks (stock plastic) due to minimal leaking. I followed the manual instructions as well as doing it the "bender" way via axial web site blog post on wraith build. I have also watch the build videos by fasteddy. I am unable to get the shock built properly. When I "bleed" and screw on the cap, the piston won't cycle. It is very stiff. The piston without the cap on, cycles smoothly. I then did it the "bender" way, where you push the shaft down then screw down. However, when holding the shaft down and screwing down, when cap reaches the seal, the seal blows it out. I am unable to consistently build via bender way and have each shock behaves the same when cycling. I have spend multi hours on this and was wondering if someone can tell me what I am doing wrong. on a side setup note, I read through beginners guide and bullet proof guide. When I flip the front shock mount over and move the upper to the inner hole, the front barely has any travel left once the car sags down. Is this normal? I am running purple springs. I know some suggests black -- which is even softer, but, I am surprised you would get any travel at all with black since it would just sag completely down. I am sure I doing this wrong. But, I am unable to find info on what I am doing wrong. I wasted so much oil I am afraid that I may run out LOL. Thanks for the help |
shock problem - Similar Threads | ||||
shock build problem | redbones | Axial Wraith | 4 | 10-05-2011 03:50 AM |
shock problem | rc demons | Losi Mini-Rock Crawler | 6 | 02-17-2011 08:27 AM |
Shock problem | Jnl1105 | Axial AX-10 Scorpion | 12 | 09-05-2010 08:37 PM |
Shock cap problem... or not? | 85V8XJ | Axial AX-10 Scorpion | 12 | 10-12-2007 09:37 PM |
savage shock problem | wheeler | General Crawlers | 9 | 01-30-2005 05:38 PM |
