11-28-2012, 02:53 AM | #1 |
Rock Crawler Join Date: Oct 2012 Location: Vermont
| Axial 5-light universal light bar wiring question...
So I ordered the Axial 5-light, light bar (same one that's on the Exo I believe) for my Wraith. I know a few here have this light bar on their Wraith. Where or how do you have it wired? I have the Axial simple light controller now for the standard front and rear lights. How much current can these safely take? I'll be running a 3S LiPo, can I tap off the battery current or is that too much voltage for the LEDs? I was thinking about installing a switch on the Wraith so I could turn the light bar on and off too. |
11-28-2012, 03:10 AM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: Axial 5-light universal light bar wiring question... Axial Racing - Axial 5 LED Light String (White LED) http://docs.axialracing.com/instruct...1-i001-nvs.pdf Operates on 4V - 9V. Last edited by JasonInAugusta; 11-28-2012 at 03:13 AM. |
11-28-2012, 04:36 AM | #3 | |
| Re: Axial 5-light universal light bar wiring question... Quote: Maybe down the road ill pick up an NVS controller. For now ill have to figure something out, maybe run the light bar off a 9V battery. | |
11-28-2012, 05:01 AM | #4 |
Pebble Pounder Join Date: Nov 2009 Location: New Bern
I used an led calculator on superbrightleds website. Mine are all wired parallel with a resistor on each led. Then wired in to a heyok light controller @ 6 volts from the receiver.
11-28-2012, 09:16 AM | #5 |
Quarry Creeper Join Date: Dec 2005 Location: the first state
i went to radio shack and the nerd that worked there punched some numbers into his calculator watch and told me which leds to get. i soldered some stuff together and it worked. not a pretty as it could be though. ps- i hooked it right to the receiver aux port then to a small switch that i put in to replace the single shifter. i also put in a connector in the roof so i can remove the 5 light bar. Last edited by bmf24; 11-28-2012 at 09:21 AM. Reason: ps- |
11-28-2012, 01:58 PM | #6 |
Hmmm, I wonder if I can tap into the current off my Castle BEC I have set to 6V for the servo?
11-28-2012, 05:59 PM | #7 |
| Re: Axial 5-light universal light bar wiring question... |
11-28-2012, 06:14 PM | #8 | |
At some point I'd like one of your units where I can turn the lights on and off via radio. | |
11-28-2012, 06:16 PM | #9 | |
Happy to get you one of my lighting controllers! | |
11-28-2012, 06:18 PM | #10 |
Perfect!
Axial 5-light universal light bar wiring question... - Similar Threads | ||||
Larry 8 LED Pocket Work Light as cheap scale light bar | spoo76 | General Scale Talk | 8 | 12-15-2014 06:38 AM |
Emergancy light bar question | braceysdad | Chit Chat | 3 | 03-16-2009 09:35 PM |
can you put light in the proline light bar? | phase | General Scale Talk | 0 | 12-13-2008 10:20 PM |
