12-13-2012, 06:05 AM | #1 |
Newbie Join Date: May 2012 Location: united kingdom
| hex??
hey all i have vanquish 350 hubs with the hex in the rear to locate into the hex on the axle...only prob is the fit between the two is quite poor creating play at the wheel. I had the origonal hexes, ive tried the asia tees ones...im i douing summit wrong? have i missed something?? better quality hexes?? ideas, cheers. |
12-13-2012, 08:02 AM | #2 |
Pebble Pounder Join Date: Dec 2004 Location: Acton
You need a washer between the nut and wheel. I noticed if on mine too my wheel nuts were cranked down and wheel still had some play. I just had to get the correct washer. What's was actually happening on mine is the hex actually protrudes out past the wheel slightly so the nut would bottom out correct washer that fit over the hex fixed any slop. Hope this helps. |
12-13-2012, 08:59 AM | #3 |
| Re: hex??
cheers dude ill give it ago when i get home, makes perfect sense....still think my hexes could be a smidge bigger though..
hex?? - Similar Threads | ||||
super berg width hex to hex | Rathgar | Superclass Crawlers | 2 | 07-19-2010 10:12 PM |
ball hex vs. hex driver | DRW-FJ40 | Newbie General | 12 | 04-07-2010 11:56 AM |
hex to hex width of WK axle? | STANG KILLA SS | HPI Wheely King | 2 | 08-17-2009 01:32 PM |
hex to hex width? | dieselfuel | Team Losi Comp Crawler | 2 | 07-28-2009 03:22 PM |
Clod hex to 23mm hex adapters? | mschaffer66 | Tamiya Clod Buster | 13 | 05-03-2006 07:04 PM |
