12-13-2012, 07:35 AM | #1 |
Pebble Pounder Join Date: Dec 2004 Location: Acton
| Cheap mod to lower your wraith
I just figured I'd share I didn't see it anywhere on here yes I searched. You want to lower the wraith easy. Rear: Flip your rear shock mount upside down gives you about the same as lowering kits. Front: is a little more involved. Cut the side brace off shock tower. Then put 1/4 spacers under it with longer screws. I then put titanium standoffs from as side braces to replace the one that was cut off. The 1/4 spacers let it sit level with rear. And it fits under panels no need to cut holes. Just thought I'd share for those on a budget like me. |
12-13-2012, 08:19 AM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: Los Angeles
| Re: Cheap mod to lower your wraith
Don't forget you can get more by flipping your lower mounts too...
12-13-2012, 10:19 AM | #3 |
Oh yeah forgot about that too. I did mine but forgot to add it. Lol.
12-13-2012, 10:51 AM | #4 |
Quarry Creeper Join Date: Feb 2012 Location: AZ
Just going with the soft 1.04 lb springs will lower the wraith more than having to mod the front end. I don't have my rear upper mount flipped and with just the lower mounts flipped and soft springs my lower links are level. I can adjust as necessary by using the preload on the shocks. I had mine really low but got high centered way too often. Since I've shortened the wheelbase to 12.5 inches I lowered it back down a little. Hopefully when my new Rock Beast II's show up, it'll raise the diffs a little since it's a tall tire.
12-13-2012, 11:24 AM | #5 |
I tried that it didn't suit my taste it still allowed to articulate more than it needed. But everybody has there their preference. But moving the shock mounts up it also limits articulation. Cause we all know our wraiths are pigs. Lol |
12-14-2012, 08:56 AM | #6 |
The other reason I didn't flip the link mounts they stick out and farther down and makes it easier to get hung up on the rocks. + you have to shorten the lower links.
12-14-2012, 10:17 AM | #7 | |
| Re: Cheap mod to lower your wraith Quote:
I've been looking at my Wraith and thinking how to lower it just a tad more and had so far only come up with some home made aluminum upper mount brackets that are not enough to require holes in the hood. I don't want holes in the hood and don't need to lower it that much. Great job and thanks for sharing! | |
12-15-2012, 04:28 PM | #8 |
I also trimmed the braces that come off the front bumper and attach to lower part of chassis. I trimmed off about 1/2". Instead of of having 2 mounting holes I just used the rear mounting holes. I already changed my braces out and made some out of aluminum links. Will post those later. If you see in the pics I have suspension travel and nothing hits. My servo tucks completely into body with no rubbing at full compression or articulation. |
12-16-2012, 12:31 AM | #9 | |
01-25-2013, 09:18 PM | #10 |
Newbie Join Date: Mar 2005 Location: riverdale
Looks good going to try it now
05-16-2016, 02:43 PM | #11 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
Thanks for the info RockBender, this is exactly the info I was trying to find for the front shock mounts
Cheap mod to lower your wraith - Similar Threads | ||||
Lower Link Mod to Make Youre life easier! | sixshooterstang | Team Losi Comp Crawler | 3 | 07-10-2013 06:57 PM |
4 link mod from stock lower links | droopmodmrc | Losi Mini-Rock Crawler | 18 | 05-04-2010 10:51 AM |
cheap mod!!! | craveman85 | Losi Mini-Rock Crawler | 11 | 04-30-2010 11:00 PM |
Cheap Sliders for your lower links | MAXIMUS | Tamiya TLT Crawlers | 15 | 03-25-2007 04:02 PM |
One motor & lower gear mod finished | crawlmaxx | Traxxas Crawlers | 1 | 09-04-2004 06:07 PM |
