10-13-2012, 08:38 PM | #1 |
Pebble Pounder Join Date: Aug 2012 Location: Salina
| Lower Link Mod to Make Youre life easier!
I removed the old lower links and made new ones using brake line, revo rod ends and 8-32 threaded rod. There are other threads going into that so I wont type all of the up but you can find info on that here: Home made lower links ? ANYWAYS! I moved the mounting location of the chassis end of the lower links from that awkward middle spot to the outside by drilling holes through the chassis plate. Then I used m3 screws and nuts along with a washer on the inside so the rod ends wouldnt rub on the chassis plate. Pictures below are pretty explanatory. If you do this take note of the following: -the revo rod ends may rub the chassis plate somewhat so use washers or a razor blade to remedy that. -if the mounting hole is too high it will cause the lower links to interfere with the uppers so be mindful of that -i took advantage of the process and made all high clearance links while i was at it BUT too much clearance causes rubbing on the upper links. |
07-10-2013, 03:29 PM | #2 |
Pebble Pounder Join Date: Jun 2006 Location: Keizer, OR
| Re: Lower Link Mod to Make Youre life easier!
anyone else do this?
07-10-2013, 03:59 PM | #3 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
It's not obvious to me that this mod would offer any performance advantages. I would also worry that the front tires would get into the lower links at full steering lock. Jerry
07-10-2013, 06:57 PM | #4 |
It looks like there would not be enough triangulation. But it is intriguing because it would help keep a flipped trans lower. I am designing a new chassis right now because I broke the stock one, and I have access to water jet but not a mill. Something like this would help simplify my skid design.
Lower Link Mod to Make Youre life easier! - Similar Threads | ||||
My life just got a lot easier | kuatto | Chit Chat | 41 | 10-16-2012 02:16 PM |
Tips to make soldering 3 wires to 1 Dean's terminal easier? | shelljeep | Electronics | 28 | 02-03-2011 04:19 PM |
4 link mod from stock lower links | droopmodmrc | Losi Mini-Rock Crawler | 18 | 05-04-2010 10:51 AM |
lets make it easier for the newbie | ROCKEDUP RICKY | Comments, Suggestions, and Help | 58 | 05-31-2009 04:14 PM |
how do I make or get templets for lower link mount | JJBADBOY | Tamiya Clod Buster | 3 | 08-09-2008 04:28 AM |
