Thread: Wide Stanced Wraith
Old 12-13-2012, 09:00 PM   #1
Default Wide Stanced Wraith
I have a set of Mayhem monster wheels on my wraith,i ran it around a little to see how it looked and perfomed with .450 hubs.Well a day or so later i figured i would change them out to the .650 hubs for more stability.So yesterday i added 6oz.of weight to the front wheels and ran it around a little today and noticed it loosened the right axle bearing.What can be done to keep the bearing from wearing so fast,or is it one of those things that will have to be replaced often?
WranglerMan is offline   Reply With Quote
Old 12-13-2012, 09:15 PM   #2
Default Re: Wide Stanced Wraith
Just like on a real vehicle the farther out you put the weight the more wear you are going to have on things such as the wheel bearings and or ball joints for example . I know that 1/10s dont have ball joints just a reference. My point being if you keep the wide spacing I would predict lots of worn bearings and you should also check the rears if you have them spaced out also you should check your axles for bending! Hope this helps even though it is probably not what you wanted to hear
gofaster427 is offline   Reply With Quote
Old 12-13-2012, 09:43 PM   #3
The driver side axle bearing wore fairly quick when i was running the stock wheels,i kinda figured the bearing was wearing because of the plastic wheels and plastic knuckles.O'h well i guess i'll go back to the .450 hubs,although i was trying to see if there was a better grade bearing to use to maybe prolong the wear.Thanks gofaster427.
Old 12-13-2012, 10:59 PM   #4
Traxxas bearings are MUCH better than stock. Fast Exdy bearings aren't as good as the Traxxas, but they are better than the stockers.
TheScaleAddict is offline   Reply With Quote
Old 12-14-2012, 03:41 PM   #5
cephas,do you have have a wraith with wider hubs?Thanks for the info,i'll look into the Traxxas bearings.
Old 12-14-2012, 04:15 PM   #6
I don't. But I have had some bearing issues.
Old 12-14-2012, 08:15 PM   #7
I'm curious if the folks that have wraiths with a wide stance have to frequently replace bearings?
Old 12-14-2012, 09:27 PM   #8
It would make sense that they would wear out faster...
Old 12-15-2012, 08:46 PM   #9
True
Old 12-20-2012, 02:22 PM   #10
I had a mini 8 with stock bearings and had played in a little mud and dirt. Next day it didn't want to roll so I ended up washing it out and put corrosion x on it and never had an issue since (couple packs in dirt and a little mud). I can keep rinsing wheels off without worrying about the bearings getting rusted.
Sna08 is offline   Reply With Quote
Wide Stanced Wraith - Similar Threads
Extra wide wraith!! (Pics) Joshs4x4toyz Axial Wraith 12 12-01-2012 05:12 AM
Wide wheels for my wraith lemarseillais Axial Wraith 13 01-21-2012 09:22 PM
Wide CC. drone6 Duratrax Cliff Climber 2 04-23-2009 03:40 PM
How wide... nd4spdbh Tamiya TLT Crawlers 3 12-05-2005 02:59 PM
