12-30-2012, 10:42 AM | #1 |
Rock Stacker Join Date: Dec 2012 Location: rochester
| shock question
Hello. 1st time post. I just got a new wraith. I had 1 of the shocks leak all the oil out 5 minutes into it 1st run. I pulled it apart to fix it and had issues with the bLadder which i think i figured out. My question is what weight of oil works best for crawling and how full should the oil be? Ive filled it close to the top but they seem way too stiff. Right now i have them 2/3 -3/4 full. Thanks
12-30-2012, 01:25 PM | #2 |
Newbie Join Date: Sep 2012 Location: ABQ
I found this helpful for shock rebuilding. Only used wraith stock shocks, so ymmv. I'm sure I found this link somewhere on this board, sorry I only bookmarked it, can't give proper credit. http://www.axialracing.com/blog_posts/1132 Good luck, I also have run between 10wt and 30... tune away, lots of discussion to read around here when you look for it. Some of it is buried in build threads... Sent from my Nexus 7 using Tapatalk HD |
12-30-2012, 03:59 PM | #3 |
| Re: shock question
Thanks for the link! That was helpful.
12-30-2012, 09:29 PM | #4 |
| Re: shock question
I found the stock shocks soft. They have almost no high speed control the rectangular oil passages flow a lot of oil and allow the suspension free movement at low speeds. The springs in my option are to stiff. Compared to shock valveing.
01-01-2013, 01:33 PM | #5 |
Newbie Join Date: Sep 2012 Location: In a House
| Re: shock question Are the kit springs better about this than the RTR? Thanks
01-01-2013, 03:31 PM | #6 |
| Re: shock question
I rebuilt both of my rear shocks. I used some thread tape no more leaks. I used 30 wt. Oil. The only issue i seem to have now is that they dont compress all the way. When im crawling over the snow hills it seems like the front socks work great. The rears are only compressing half way. Should i try a 10wt. Oil? Id like to get as much suspension travel as i can.
01-01-2013, 03:35 PM | #7 |
| Re: shock question
i have the kit wraith i built the shocks and installed them then took them right off because ride height was so tall. i revalved and messed with springs on 1/8 scall buggy front shocks and am loving them. im building a inda formula offroarder these shocks are working well after being worked over at slow speeds they allow the suspension to move and also handle very well at speed Last edited by evan03; 01-01-2013 at 03:40 PM. |
01-01-2013, 04:48 PM | #8 | |
If you need more low speed shock travel I would look at spring, lean then forward in the mounting holes or try softer springs... oil its not what you are after for that situation unless they are so slow they just don't respond, but 30wt with the rtr pistons wouldn't put you there. You also can drill out your pistons, or try some of the others included on the part trees... good luck. Sent from my Nexus 7 using Tapatalk HD | |
01-01-2013, 04:58 PM | #9 |
| Re: shock question
stock shocks feel very soft but the springs in my opion are stiffer then valveing. stock shocks in my opion just arent very tunable. heres how i valved the 1/8 buggy shocks. enlarged 3 of the holes for slow speed action and 3 3 small for high seed. the stock shocks have big rectanugular ports that limit little to no oil flow. cant see why drilling them would be needed since theyre already valved for crawling. |
01-02-2013, 11:16 AM | #10 |
| Re: shock question
Without the springs theyre really stiff the last 3/8 inch or so. Ive bled and rebled with no chnge. I may try to change pistons and see what that does.
01-02-2013, 11:33 AM | #11 | |
01-02-2013, 11:37 AM | #12 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Do your pistons still have the little plastic burs on them. They will bind up the suspension movement and create sticktion...might be your problem Sent from a rock |
01-02-2013, 03:03 PM | #13 |
| Re: shock question
No burs. And yes. It feels springy when i compress them.
01-02-2013, 05:51 PM | #14 |
| Re: shock question
Ithink i got emgood now. I replaced the 2 hole pistons with 3 hole and added a 4th. I getting full compression on them now. Thanks for all the info from everyone. Im so used to slash 4x4 and revo shocks. This crawling thing is a different animal, but i like it. Very addicting! Cant wait to do some upgrades to this. Just gotta figure out what to upgrade.
01-02-2013, 07:10 PM | #15 |
01-02-2013, 07:29 PM | #16 |
| Re: shock question
I was looking over the stuff that came with my kit and noticed difrent valves. Looks you for it figured out. I think the stock shocks and springs will work well for all around Wheeling think about tossing mine on now that I've got quite abir of run time on the buggy shicks |
01-09-2013, 07:50 AM | #17 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| Re: shock question
So whats the consensus on oil weight fro crawling? Also, there are 3 top mount holes, which one? |
01-09-2013, 06:05 PM | #18 |
| Re: shock question
30wt seems fine to me
01-09-2013, 09:26 PM | #19 | |
Quarry Creeper Join Date: Feb 2012 Location: AZ
| Re: shock question Quote:
01-10-2013, 04:18 PM | #20 |
| Re: shock question
Still wondering about mount position
shock question - Similar Threads | ||||
Shock question?? | asian195 | General Crawlers | 1 | 05-28-2012 09:25 PM |
Shock question | James003 | Axial XR10 | 4 | 05-02-2011 02:58 PM |
shock question | crawlerknownothing | Losi Micro-Rock Crawler | 4 | 02-10-2011 09:59 AM |
Shock question | soundcolor | Losi Mini-Rock Crawler | 3 | 04-09-2009 08:53 AM |
shock question | pedemaster-rc | General Crawlers | 7 | 04-08-2006 09:31 PM |
