Thread: Alright... So I'm torn (motor)
Old 12-31-2012, 02:46 PM   #1
Default Alright... So I'm torn (motor)
I'm sure most of you in this forum have seen my wraith... I've had it since day one of RTR launch. Thinking im not a noob at this point, but then I start thinking about motors and it would seem I AM in fact noobtastic.
So I was pretty sold on the MMP and Pro4 set up. But living in Colorado Springs, I find myself driving through some pretty gnarly shit. I know there's not a brushed motor that can touch the pro4 for straight speed... But I am building this guy up as a TTC competitor for next June...... Mud, snow, grime, dust and dirt are definitely on the menu.
Ok, rambling. Should I get a MMP and Pro4 combo or should I rock the AE2 and pick up a Holmes TrailMaster? Is there a brushed set up that will give me even close to the wheel speed of the pro4? My drivetrain is prepped for abuse so that's not an issue. Just need a new power plant. What do I do?
I have the cash for either I just can't pull the trigger! I'm torn. I need guidance!
Soulo747 is offline   Reply With Quote
Old 12-31-2012, 02:54 PM   #2
666
MODERHATER™
666's Avatar
Default Re: Alright... So I'm torn (motor)
Waterproof a Pro4, get a Tekin RS Pro, or a Mamba Pro, waterproof them, and go for it! You will not regret it!
666 is offline   Reply With Quote
Old 12-31-2012, 02:55 PM   #3
Can you link me to a waterproofing tutorial?
Old 12-31-2012, 03:11 PM   #4
666
MODERHATER™
666's Avatar
There is this:
Originally Posted by War Pig View Post
This is what I have done with mine.
Pro4 motor:
Disassembled and sprayed the sensor board with 3 coats of conformal coating. Reassembled. After soldering on the motor wires I put a bead of electronics safe silicone between the case and wires and around the sensor plug receptacle. I also plugged the extra threaded holes (where the motor bolts to the motor plate) with 3mm plugs with blue loctite.
RS Pro:
Removed case and sprayed with 3 coats of conformal coating. Reassembled. Installed the sensor wire with a dab of dielectric grease. Dipped in plastidip. Ziptied sensor wire bundle together, motor wires and + - together and plastidipped again.
I have all the other electronics in a waterproof box and are sealed up.
As you can see by the video, it seems to be pretty waterproof! The day before this I actually had it in water over the roof....all you could see was the headlights underwater .
And if you do a search in the electronics section there are a few threads on it.
Old 12-31-2012, 04:19 PM   #5
Thx man. Any other opinions?
Old 12-31-2012, 07:45 PM   #6
I run a mmp and pro 4. You will never go wrong with a mamba max pro! It will do damn near anything. If you can get the pro 4 waterproof your set. Mine will crawl as slow as I want and go as fast I need it to
CRAWLERJOE is offline   Reply With Quote
Old 12-31-2012, 10:51 PM   #7
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Brushed wont stack up to a Pro4.
Harley is offline   Reply With Quote
Old 01-01-2013, 03:27 PM   #8
Period eh? I figured as much. Thx
Old 01-02-2013, 09:22 AM   #9
I'm having the the problem you are, I want to keep the motor/esc as cheap as possible though being that I don't crawl much ( Only in the winter when racing seasons out.
simpson1550 is offline   Reply With Quote
Old 01-02-2013, 09:27 AM   #10
20K Club
Harley's Avatar
Cheap is not too hard to do. You get what you pay for. There is no secret to getting Pro4 power for Integy prices
Alright... So I'm torn (motor) - Similar Threads
torn between 2.2 and 1.9 jimbob78 Axial SCX-10 18 07-15-2012 04:44 PM
Im torn h8z2luze Tires and Wheels 5 07-07-2009 09:31 AM
So I'm torn... Hyde Axial AX-10 Scorpion 10 02-21-2009 01:46 PM
New Torn Grappler prdquik Paint and Body 13 06-21-2008 12:44 PM
