01-10-2013, 03:57 PM | #1 |
Newbie Join Date: Jan 2012 Location: battle ground
| spur gears
iv spent probable 10+ hours searching and havent really found a anwser(found my same question many times) but what im looking for is what spur gear work with a wraith? not what gear ratio's or the differance between 32p vs 48p but what to ask for/look for when buying one? for example, i picked up a traxxas spur from a jato from the lhs the other day trusting he knew what he was talking about but got curious when he called to ask another store if it was correct. i think a list of direct bolt in spur gearfor noobs like me would be good Last edited by popeye123; 01-10-2013 at 04:03 PM. Reason: changed mind |
01-10-2013, 04:03 PM | #2 |
| Re: spur gwars Choosing a motor and ESC for your Wraith - Gearing Added! I run a 32p Traxxas spur and Robinson Racing 32p pinion. It really doesn't matter that much as far as brand. IMHO, 32p is far better than 48p. And you can start with a 5:1 ratio (or around there) and adjust as needed. |
01-10-2013, 04:37 PM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: AZ
| Re: spur gears
I've had good luck with the Duratrax spurs. I like that they are a tight fit in the center hole, that way I know the spur is centered perfectly. And they're cheap |
01-10-2013, 05:00 PM | #4 |
| Re: spur gears
The Kimbrough 54 Tooth 32P Spur Gear #129 is a perfect fit. Kimbrough 54 Tooth 32P Precision Spur Gear |
01-10-2013, 06:38 PM | #5 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: spur gears |
01-10-2013, 07:03 PM | #6 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| Re: spur gears
WOW! This is great to know. I was planning on driving WAY out of my way tomorrow to go to the closest shop that has Axial stuff. Now I can grab any 87 (assuming they have an 87) from the MUCH closer shop. |
01-10-2013, 10:25 PM | #7 |
Rock Stacker Join Date: May 2010 Location: tx
| Re: spur gears
Im running a RTR with 87 spur and 15 pinion with a 45t motor and it crawlers way better.
spur gears - Similar Threads | ||||
Micro T spur and Micro Crawler spur gear. Same thing? | matts175 | Losi Micro-Rock Crawler | 4 | 10-15-2011 01:18 AM |
What Spur for TF ? | 4XADICT | General Crawlers | 3 | 10-01-2004 02:30 AM |
