01-21-2013, 03:10 AM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: Michigan
| Wraith question!!!
Hey guys got a wraith kit awhile back and started to assemble her the other day with some electronics I had laying around. However I just got it going today and was going to check it and one Alex spins on way and the other will spin the other direction. What did I do wrong here??? It has puzzled me all day and don't know what's going on with it. Thanks Evan |
01-21-2013, 05:56 AM | #2 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
| Re: Wraith question!!! Last edited by rm25x; 01-21-2013 at 06:00 AM. Reason: added picture |
01-21-2013, 07:20 AM | #3 |
Newbie Join Date: Dec 2012 Location: Ridgefield
You most likely put the rear diff in wrong. There is a misprint in the directions say x2 for the front axle only and doesn't show a picture of the rear one exploded. I made the same mistake when i built my wraith.
01-21-2013, 04:16 PM | #4 |
Thanks guys when I was going back thru the book I caught it. It was the rear one flopped in backwards
01-22-2013, 08:55 AM | #5 |
Newbie Join Date: Nov 2012 Location: Billings
I did the same thing just after christmas. My 4 yr old was looking at it like what did you do dad? Pretty easy fix though.
01-30-2013, 01:41 PM | #6 |
Newbie Join Date: Jan 2013 Location: Portage
Hey everyone, I have a question on the wraith kit and could use a little help. I just finished the build but have noticed the front wheels are not very stiff... they wobble a little. I tracked the problem to the axle shafts that came pre-built and it seems the rod at the pivot has slack / space in it. Has anyone else had this problem?
01-30-2013, 04:35 PM | #7 |
Pebble Pounder Join Date: Jan 2013 Location: Seattle
My front axles move in and out of the knuckles a little, enough to even budge the bearing. I figured this was "normal", since the CVDs slide out a bit more than expected. I'd like to know if this should NOT be happening?
01-31-2013, 12:43 AM | #8 |
Pebble Pounder Join Date: Feb 2009 Location: New York
My wraith kit came with one front shaft that was stiff & bound up tight. |
Wraith question!!! - Similar Threads | ||||
Wraith Question | Hawthorne46 | Axial Wraith | 20 | 07-03-2012 01:43 PM |
wraith question | spanky97 | Axial Wraith | 7 | 12-10-2011 12:22 PM |
wraith question | rmiranda134 | Axial Wraith | 3 | 11-15-2011 11:48 AM |
Wraith question | adamlee78 | Axial Wraith | 14 | 10-20-2011 10:18 AM |
Wraith kit question | EMUTT | Axial Wraith | 10 | 10-09-2011 06:25 PM |
