01-21-2013, 08:09 PM | #1 |
Newbie Join Date: Oct 2012 Location: Camden
| pinion gear rubbing cover
i installed a traxxas 52 tooth 32p spur ,and a 16 tooth pinion. It was all i had at the time that would fit my motor shaft. anyway after i got it all bolted up i noticed that it seemed a little stiff ,but i powered it up and ran it across the floor . It made on heck of a noise . so i took it back apart i noticed inside my pinion /spur cover that the pinion gear had been rubbing the front of the cover and cutting a groove in it . I could of swore i read about people running bigger than that with no problems . reckon why mine is givin me troubles ? Whats the biggest 32p pinion you guys use ?
01-22-2013, 07:34 AM | #2 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
| Re: pinion gear rubbing cover
If your talking about the pinion (the small one), slide it back towards the motor some. I have a 56 tooth Traxxas spur (the large one) x 12 tooth pinion and it does not rub. This equals out 4.666/1
01-22-2013, 09:37 PM | #3 |
only problem with that is that ive got it as far back as i can get it . mite have to just find a different style pinion . One that s not as long
01-24-2013, 06:48 AM | #4 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
intresting... im running a 54t/ 18t-20t and it didnt rub at all... pic of gear perhaps?? |
pinion gear rubbing cover - Similar Threads | ||||
Who's for a clear lexan spur/pinion cover? | SwampDawg | Axial Wraith | 16 | 09-25-2012 08:58 AM |
Spur gear rubbing? | Man of 5lay | Axial SCX-10 | 5 | 05-01-2011 09:47 PM |
Can't put the gear cover | clowkoy | HPI Wheely King | 8 | 03-28-2008 07:39 AM |
WK gear cover ?? | solomon7 | Newbie General | 11 | 08-26-2007 11:59 PM |
Gear cover | scruff007 | Tamiya TLT Crawlers | 2 | 08-15-2006 08:30 PM |
