01-25-2013, 09:57 AM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: poplar blufff,mo
| tranny advice
got a sensored 13.5 and 17.5 an losi esc. i need a tranny. what i have already is a r2 that needs rebuilt. 15.00 or buy a stock ax10 tranny with slipper? i know the axial will need gear upgrades and 32p spur and pinion. my question is should i just go with the r2 rebuild it and be good? or get a axail run it like it is and upgraded later? can the axail handle 13.5 or 17.5 power in stock form? for a couple of months with 2s lipos not a speed rig trails and crawling only? |
01-25-2013, 10:13 AM | #2 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: tranny advice
In the long run you should go with the Axial. Durability is higher in my opinion with upgraded gears.
01-25-2013, 10:23 AM | #3 |
| Re: tranny advice
thats were i was leaning too. but my question is if only crawling will the will stock axail hold up? i know its more of when it fails and not if it fails but my funds dont allow for tranny and gears from the start. oh well on to the classifeds |
01-25-2013, 10:33 AM | #4 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
| Re: tranny advice
There's a lot of people that are still running the stock trans gears. I've seen first hand a Wraith with a VXL system on 3S take a beating without breaking anything, also seen the same rig with a HH BRXL & 7T Puller on 3S do some wicked stuff with no broken parts. A big factor in my opinion would be proper setup of your slipper and control of your throttle finger.
01-25-2013, 10:41 AM | #5 |
I ran stock gears for a long while with a nocak 17.5/tekin rs on 3s. The older, hollow alum outputs are the only stock item I refuse to run.
01-25-2013, 10:42 AM | #6 |
| Re: tranny advice
ok thanks guys those were the answers need!!!
01-25-2013, 03:41 PM | #7 |
| Re: tranny advice
i ran the castle sv2 4600 system for awhile on 3 cell with no damage, i later changed to 2100kv 2250watt 1/8 scale motor and stripped the idler gear running on 5s. i changed to a robinsion idler and have been going strong for awhile and have ran 6s lipos on it. i did stripp the idler when the paddles were loose then hooked up hardcore literaly instantly stripped the idler. |
01-25-2013, 06:32 PM | #8 |
| Re: tranny advice
evan03, there's no chance for a warning when that happens, HAHA.
tranny advice - Similar Threads | ||||
AE B4 tranny advice | mrbenn | Tamiya TLT Crawlers | 1 | 07-06-2007 03:50 AM |
emaxx tranny and pede tranny gear ratio questions | CRAWLOVERYOU | General Crawlers | 3 | 12-28-2004 01:28 PM |
