01-27-2013, 09:56 AM | #1 |
| Proline Rubicon body hitting steering servo
I'm mounting a Proline Rubicon body # 3380 and when I compress the suspension it's hitting the steering servo and it looks like I need to trim the grill to fit it. It's not hitting by just a little either, it's hitting the servo on the top of the case. I've seen only one other mounted and they had trimmed the front grill on the body. The body on the Proline site isn't trimmed but looks like it's sitting inside the stock bumper pretty far. I also mounted with stock position on cage, any ideas? |
01-27-2013, 10:28 AM | #2 |
| Re: Proline Rubicon body hitting steering servo
CMS, or you could probably move the servo back just a bit.
01-27-2013, 10:48 AM | #3 |
I knew someone was going to say CMS I'll need to check if I have enough room to move it back, looks like the servo arm is still pretty close to the pumpkin. |
01-27-2013, 10:54 AM | #4 |
Also, what links are you running? You could shorten them a bit to move the axle back and get it to clear that way.
01-27-2013, 10:58 AM | #5 |
Hmm, that's a really good idea that I totally missed. I the stock links but the kit was assembled by someone else. I wonder if the shorter ends will fit on them.
01-27-2013, 11:13 AM | #6 |
You can take an exacto knife and shave down the rod ends to make them a bit shorter as well. And if your lower link/shock mount is flipped you can flip it back to stock and shorten it up about 1/4".
01-27-2013, 11:31 AM | #7 |
Just checked it out. The stock top links are one piece and have the bottom threaded kit links. It looks like that servo is just way taller than the other ones. I might see if another servo will fit in there. I do have a set of custom links I did up for the other wraith that I could shorten too and install. That's probably going to be the best bet.
01-27-2013, 07:08 PM | #8 |
Rock Stacker Join Date: Jan 2013 Location: garden city
hey ive been thinking of ordering that same servo how do you like it?what voltage are you running to it? does it seem like the torque rating is true? and does it get hot i hear that it gets extremely hot?
01-28-2013, 07:32 AM | #9 |
Quarry Creeper Join Date: Jan 2010 Location: Lunenburg
Look at my thread for moving the servo back. It's the PL Bronco body but should be similar. Wraith re-build with PL Bronco body |
01-28-2013, 07:32 AM | #10 |
No word on the servo yet, plan to drive this weekend when I get things more sorted out in the truck.
01-28-2013, 10:31 AM | #11 |
So, I ended up trimming it a bit and the fit is pretty good. It slides up into a nice notch about 1/3 of the way up the grill. The bumper covers most of it so it looks pretty good. I'll post some pics in a new build thread.
Proline Rubicon body hitting steering servo - Similar Threads | ||||
proline 4dr rubicon and proline interior ? do they work together? | Tmods | Paint and Body | 12 | 01-19-2014 11:57 AM |
servo hitting crossmember | zero1 | Axial SCX-10 | 10 | 06-06-2012 01:41 AM |
Steering link hitting frame? | Aramis76 | Axial SCX-10 | 10 | 01-06-2012 12:51 AM |
Servo hitting my shocks. | DaSamurai | 1.9 Scale Rigs | 1 | 09-20-2009 06:03 PM |
