01-29-2013, 11:22 AM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
| to shim or not to shim
I need to replace diff gears in my wraith due to wear abd was told that I should shim the gears when I put them in. I was wondering if this necessary and how many do this.
01-29-2013, 11:28 AM | #2 |
Rock Crawler Join Date: Nov 2010 Location: south prairie
I'd like to know too, I got my first set of wraith axles coming soon.:thumbup: sent from a mobile device dumber than me. |
01-29-2013, 11:30 AM | #3 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
| Re: to shim or not to shim
i guess it depends how sloppy the pinion gear is with the driveshaft installed.
01-29-2013, 11:49 AM | #4 |
Rock Stacker Join Date: Dec 2012 Location: Staley NC
I have been building 1-1 differentials for 14 years now and you need some back lash 1 to 1 is generally 6-10 thousandths if that gives you any idea just dont build it to tight it will cause your gears to wine and wear.
01-29-2013, 11:57 AM | #5 |
| Re: to shim or not to shim Thats what I was thinking. I was afraid of getting it to tight and basically cause binding or excess resistance.
01-29-2013, 12:06 PM | #6 |
X2. I've never had to space scx10 axles cause the fit was good. We will see when my axles get here. Thanks sperd:thumbup: sent from a mobile device dumber than me. |
01-29-2013, 04:48 PM | #7 |
Pebble Pounder Join Date: Feb 2009 Location: New York
On my 1:1 Jeep I shimmed them as you should. But on my RC's I have never had had to shim an axle gear set.
01-30-2013, 12:47 AM | #8 |
| Re: to shim or not to shim I always shim RC diffs and trannies, SCX Honcho and AX-10 were pretty loose and needed lots of shimming especially in the diffs. Wraith was much better and needed almost zero shimming. A little loose is better than too tight, but most are way too loose without any shims.
01-30-2013, 11:32 AM | #9 | |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: to shim or not to shim Quote:
Too tight? Just right? I know we are talking about a feel / experience thing but I wonder if there are some indicators a less experienced person could use. I have been running the stock ring & pinions on my Wraith with the dog bone axles. I am upgrading to lockers, universals, AL bearing caps, Brz bushings on pinion shafts & HD ring & pinions so if I need to shim I would like to take care of that when I am doing all the others. | |
01-30-2013, 05:08 PM | #10 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
After installing hd gears and vp everything i used these TowerHobbies.com | Team Durango Shim 5x8x.5mm (10) on the exterior of the pinion shaft. I tried it on the inside but it made the gears too tight. Theres prolly a 1mm gap between my mips and the pinion bearing, by putting 2 shims there it stops the pinion from moving in!
to shim or not to shim - Similar Threads | ||||
pinion shim | rockerrc | Tamiya TLT Crawlers | 10 | 12-21-2012 07:41 AM |
pinion shim | runnerover | Losi Mini-Rock Crawler | 0 | 04-20-2010 09:44 AM |
How to shim?????????????? | squad2man | Newbie General | 1 | 03-25-2010 08:14 AM |
Shim size | Mortimer Snerd | Axial AX-10 Scorpion | 0 | 05-04-2009 08:56 PM |
