02-04-2013, 03:38 AM | #1 |
Rock Stacker Join Date: Oct 2012 Location: birmingham
| Wraith Questions
I have a Wraith with all kinds of upgrades.... needless to say the redline 13.5T is a lil weak on the slow crawlng side. I wanna do a 32P conversion. What brand of spur bolts up the easiest? Also. I see people with a CMS only running 1 upeer link. Why is this? I have all 4 links in the front and it works fine. I make these skid plates... |
02-04-2013, 07:30 AM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
| Re: Wraith Questions
E revo spur will bolt up and is the cheaper route. If you use a tapered grinding stone for a dremel and just ever so slightly enlarge the holes the spur will mount right up and run as true as stock.
02-04-2013, 08:08 AM | #3 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
Theres a thread somewhere here that lists a few different spur gears that should fit.
02-04-2013, 09:19 AM | #4 |
| Re: Wraith Questions It may seem like it is working fine but if you are running all the links and a panhard you are introducing binding into your suspension. It is just a fact based on geometry. A CMS with panhard needs to run a 3 link or a PARALLEL 4 link which the wraith is not setup for.
Wraith Questions - Similar Threads | ||||
Wraith Upgrade Questions! | bpo35 | General Crawlers | 4 | 07-05-2012 12:58 PM |
wraith flex questions | bashin calfee | Axial Wraith | 48 | 03-13-2012 12:34 AM |
Wraith Questions | sullivanscx10 | Axial Wraith | 10 | 01-22-2012 09:14 AM |
XR-10/Wraith knuckle questions | Jus | Axial Wraith | 2 | 10-28-2011 05:26 PM |
wraith questions | wraith_1986 | Axial Wraith | 1 | 10-17-2011 12:27 PM |
