02-06-2013, 12:16 PM | #1 |
Newbie Join Date: Nov 2012 Location: Port Lavaca, Tx/Boonville, In
| Battery run time question.
On a new stock Wraith, how much run time would you expect from a new lipo Venom 5000 2s 25c battery? I have charged mine twice. On the first charge I got about 40-45 minutes in grass and blacktop. On the second charge, I got about 1-1.5 hours playing on a loose dirt hillside. Neither of these are inline with what I expected. Scratch that. After looking at the clock, the second charge was also sub one hour. Last edited by twentyfootdaredevil; 02-06-2013 at 12:27 PM. |
02-06-2013, 01:30 PM | #2 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
| Re: Battery run time question.
my gens ace 5000mah 40C lipo last between 1hour and 1 hour 45 minutes crawling
02-06-2013, 01:38 PM | #3 |
Thanks for the reply . So my run times are a little low but, can be due to more throttle on the climbs. I thought I would get more run time out of the bigger battery. |
02-06-2013, 01:47 PM | #4 |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
Does your charger tell you how much went into the battery? Maybe you're not getting a full 5000mAh into it? Sean |
02-06-2013, 01:52 PM | #5 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
All depends on how your driving it and what setup you have
02-06-2013, 02:02 PM | #6 |
| Re: Battery run time question. |
02-06-2013, 04:01 PM | #7 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
Do u gun it full throttle alot.....if so that chews up mah quick.
02-06-2013, 04:31 PM | #8 |
| Re: Battery run time question. Grass probaly sucks more power than you think. Just imagine as a kid riding your bike it the grass compared to blacktop
02-06-2013, 04:37 PM | #9 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
my venoms are a year old and still give me 1 3/4- 2 hours each. I run both 30 and 40c 5000mah. I run a goat 3s with the 13.5 motor lower times were heavy throttle sand wash runs on the rocks where full throttle is not required gave longer runs., bone stock brushed and new batts it ran over 3 hrs. have you tried to contact venom about this? try a different battery if you have one and see what happens
02-06-2013, 07:34 PM | #10 |
Well I had a stock Wraith for one day I just installed a Goat 3s and a Novak 21.5 turn motor. I had a few 3s batteries so this was bound to happen.
02-07-2013, 02:49 AM | #11 |
I have a 3s 3300mah that I use in my wraith. I range from 1hr to 1 1/2 hours with a HH brushed motor. When I get the brushless in in guessing it will be down to 45min to an hour. Brushless will get you less run time than a brushed motor.
02-07-2013, 10:03 AM | #12 |
On a 35T brushed motor with a 4300mah 3s I've gotten over 3 hours of run time before.
Battery run time question. - Similar Threads | ||||
Battery and run time question | rockhound | Losi Mini-Rock Crawler | 8 | 03-06-2013 10:21 AM |
Battery run time ? | mikey4play | Newbie General | 3 | 10-30-2010 06:45 PM |
battery run time losi battery | perez62682 | Team Losi Comp Crawler | 4 | 03-14-2010 08:22 PM |
battery run time | piper92 | Electronics | 2 | 10-28-2008 12:57 AM |
Battery Run Time | JasonA | General Crawlers | 2 | 11-14-2006 10:29 AM |
