02-09-2013, 04:44 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Seattle
| I think I killed my HH TorqueMaster BR-XL
Well, this isn't good. I have a basically new HH TorqueMaster BR-XL waterproofed (by HH) ESC, hooked up to the HH CrawkMaster Pro 540 motor. I was out on my second outing with my wraith. About 20 minutes of sloooow crawling over stuff, a little bit of water, but nothing reaching the ESC or the motor. I stopped it to take a few pictures, kept going, stopped again to take a few more. Suddenly, the Wraith wouldn't reverse, only moved forward, and very jerky. Then it wouldn't move forward at all. I couldn't figure out what's wrong in the field, so I came home for diagnosis. The ESC arms and "beeps" the motor as usual. I get a green light on forward, and a red light on reverse. But according to my volt-meter, I get absolutely no juice coming out of the motor leads. I get 0 volts forward, and -0.05 volts in reverse. I hooked up a different motor to the ESC, same symptoms. I hooked up a battery directly to the CrawlMaster Pro and it spun up like crazy. My receiver and steering servo (powered via Castle BEC) work fine. So it has to be something with the ESC. Any ideas? I'm going to try to get in touch with HH on Monday, but this is really depressing. One thing I didn't get is the ESC temperature out in the field when it failed. However, it was cold out, and it's well ventilated. At home, though, even with nothing moving, it heated up pretty hot to the touch. Not sure if that's normal or not. Edit: I just realized I should have posted this in the electronics forum, sorry! Last edited by MetalNut; 02-09-2013 at 05:00 PM. |
02-09-2013, 04:52 PM | #2 |
| Re: I think I killed my HH TorqueMaster BR-XL
Tried a fresh pack?
02-09-2013, 04:55 PM | #3 |
Yes, I tried two different Lipo packs and even a regular NiMH pack |
02-09-2013, 05:29 PM | #4 |
Rock Stacker Join Date: Apr 2011 Location: 303
I have had two waterproofed br-xl's an cooked them both I think it's the waterproofing I have a br-xl with out proofing an it's lasted for two years an going.. Just contact him on his site he'll help u out..... |
02-09-2013, 05:48 PM | #5 | |
| Re: I think I killed my HH TorqueMaster BR-XL Quote:
I don't understand how I could have fried it. I was out there for 20 minutes, 5 of which was standing still and taking pictures, the other 15 being slow crawling. It would seem, in my novice opinion, that I was within operational limits. And it's about 45 degrees out today. I'm actually wondering if mine was bad. I couldn't hook it up to the Castle Link unless I gave it external battery power and used a no-red-wire extension between the ESC and the Link. If I tried a direct hookup, the Castle Link board would just get hot and nothing else would happen. I also had some intermittent issues with the ESC just going into red-flashing-LED mode, which would usually get resolved by re-plugging the battery in. Who knows. I'll ping HH. Last edited by MetalNut; 02-09-2013 at 05:53 PM. | |
02-09-2013, 06:43 PM | #6 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Yeah I am thinking the waterproof coating could be the problem. On a total side note. I have a Kyosho Blizzard SR with a dual motor controller ESC called a Sabertooth. I used CorrosionX on it and I had some issues after using it for a few minutes. I just gave the big power caps a few taps and the power came back!! It was weird so maybe the waterproofing masks poor factory solders or something. The ESC works fine now and if it ever dies again I will just try tapping the caps. Very bizarre and sorry to sidetrack this thread. |
02-09-2013, 06:51 PM | #7 | |
The BR-XL will fry if you have the red lead from the ESC and the CCBEC both connected to the receiver. | |
02-09-2013, 06:51 PM | #8 |
It's hard for me to believe that a reputable company such as HH would sell an ESC that couldn't handle less than 2 hours of total runtime. I'm hoping it's a manufacturing defect.
02-09-2013, 06:52 PM | #9 | |
Last weekend, I had the Wraith out for about an hour and a half with no problems. | |
02-09-2013, 06:59 PM | #10 | |
I have had 2 of the waterproof BR-XL's now for over a year with no issues. Must have run at least 50 to 60 packs on each. | |
02-09-2013, 07:01 PM | #11 |
| Re: I think I killed my HH TorqueMaster BR-XL Wouldn't the ESC not arm if the throttle trim was the issue? It beeps the motor in the same pattern is has when it worked, and it arms since I get the green/red forward/reverse lights.
02-09-2013, 07:22 PM | #12 |
I got the trim off just a little and the ESC still armed. It would go for a little bit and then just stop and shake. Putting the trim back into the center fixed it.
02-09-2013, 07:28 PM | #13 |
I just double-checked, throttle trim is at 0
02-09-2013, 07:34 PM | #14 |
Rock Crawler Join Date: Jun 2011 Location: Las Vegas/671
Did you mess with the settings prior to using the BRXL? If you did, try upgrade the firmware.
02-09-2013, 07:42 PM | #15 |
| Re: I think I killed my HH TorqueMaster BR-XL I'm not sure I follow. I got the ESC less than a month ago. I had trouble connecting it to the Castle Link, but I only did so to verify the settings. I didn't change any. I also changed nothing since last weekend, when it ran fine. And it ran fine for 20 minutes today, prior to the failure.
02-09-2013, 07:49 PM | #16 |
Did you have a read of the manual for BR-XL? Just for something to do. http://holmeshobbies.com/Common%20fi...ion%201.08.pdf |
02-09-2013, 09:18 PM | #17 | |
02-09-2013, 09:49 PM | #18 | |
I haven't heard much negative stuff about the br-xl and I've run 2 on 6s, underwater, in mud, tug o wars and snow... you name it, for over a year with no problems. I think there's a 90 day warranty on the wp versions. Last edited by johnnyh66; 02-10-2013 at 11:14 AM. | |
02-09-2013, 09:53 PM | #19 |
| Re: I think I killed my HH TorqueMaster BR-XL See, this is what I want to hear I've been SO gentle with it, that I can't imagine any failure is my fault. Either way, I'll get in touch with HH Monday, so keep your fingers crossed.
02-10-2013, 10:30 AM | #20 |
I've plugged brand new ESCs (plural) in and they've gone poof in the first foot. FET pops and smokes. It happens. I've also ran various brand controllers for MANY battery packs then all of a sudden, poof. Electronics do that. Your EE class text books should have a chapter about that. I used a prototype BR-XL for years, then one day it met it's death in a sweet smoke show. I've used many Tekin and a few Novak controllers for years, some live on some die. |
I think I killed my HH TorqueMaster BR-XL - Similar Threads | ||||
somebody killed bigfoot..... | ScaleReady | Chit Chat | 11 | 08-30-2012 10:34 AM |
You killed the FJ40 for this?! | microgoat | 1.9 Scale Rigs | 9 | 02-29-2012 07:21 PM |
killed 3 servos....now what? | GSRswapandslow | Electronics | 19 | 05-12-2009 08:44 PM |
I think I killed my Goat... | fatwoul | Electronics | 15 | 09-16-2008 08:47 AM |
Help!Help! I think I killed it | SouthernHighLife4x4 | General Crawlers | 11 | 06-04-2006 09:48 PM |
