02-13-2013, 04:32 PM | #1 |
Newbie Join Date: Feb 2013 Location: Crawlerville
| Wraith rear axle issue
Hello again, started on my wraith build today and have a problem with the rear axle assembly. The left side (short) axle shaft seems to be 1/2mm too long. The axle shaft fully seated (turns freely) and the outer bearing installed the lockout ends up a half a hole shy of aligning up with the housing. Has anyone else had this issue and can I simply mill the shaft length down until the lockout hole is aligned with housing hole? Any help would be greatly appreciated. Papa |
Wraith rear axle issue - Similar Threads | ||||
Rear axle short shaft issue? | Katan | Axial Wraith | 216 | 04-24-2017 06:46 AM |
rs10 rear axle issue | tpain123 | Redcat Crawlers | 5 | 05-16-2011 07:22 AM |
Rear axle low end issue | Cube | General Crawlers | 1 | 10-18-2006 11:18 AM |
