Thread: More crawl?
Old 02-18-2013, 12:09 PM   #1
Default More crawl?
I want my Wraith to be as crawl set as possible.
This week, I put XR10 wheels (weighted) with panther tires from my wifes truck on my Wraith. 100% BETTER! Seriously.
I've ordered a set of XR10 wheels.
What other mods can I do to lower COG or make it more crawl capable?
I'm planning on moving my electronics around to fit my battery under the hood.
I'm thinking of trimming my Ripsaws.
I saw mention somewhere of flipping the lower shock mounts. Is this good? I'm looking for mods to the excisting truck. Not big purchases. Any small tricks basically.
Bansh88 is offline   Reply With Quote
Old 02-18-2013, 12:26 PM   #2
Default Re: More crawl?
What gearing are you running? And if you want a great tire get some pit bulls. Night and day difference
throttlejock27 is offline   Reply With Quote
Old 02-18-2013, 12:30 PM   #3
I'm running 87/14 gears.
Those Panthers are gripping sweet. Was thinking of Sedonas just to be different.
Old 02-18-2013, 01:55 PM   #4
Flip rear shock mount, move battery to the front, find some softer springs and give your suspension some droop
slash 127 is offline   Reply With Quote
Old 02-18-2013, 02:05 PM   #5
You can also buy a droop kit or just make your own. And like you said moving your battery to the front will be better.
Old 02-18-2013, 03:20 PM   #6
Flip the shock mounts on the axals shafts and move the shocks the the most inboard holes or just get a droop kit and softer springs.
puddin is offline   Reply With Quote
Old 02-18-2013, 03:28 PM   #7
Droop? Explain kit vs do it myself.
Old 02-18-2013, 03:33 PM   #8
Droop is when your shocks are nearly bottomed out at ride height...you can establish it my some shorter springs or just loosening your threads on your shocks
Old 02-18-2013, 03:34 PM   #9
Level3 RC AXIAL WRAITH RC CRAWLER CUSTOM SHOCK DROOP SETUP
Old 02-18-2013, 06:15 PM   #10
What kind of trick is used to mount battery up front. The first slot in front of the cab. I'm using good sized batteries
Old 02-18-2013, 06:34 PM   #11
You relocate the ESC and receiver box to make room for the battery. You can either make or buy a plate to mount the battery on. You can hinge the hood or use 4 body posts/clips to fasten the hood. I can put a 3S 5300mah battery up front with room to spare. These 2 links have what I did to relocate the battery up front. There are multiple ways to do this.
Interior mod to install Crawler Innovations front electronics tray
Flatbed Rubi Wraith
k7zpj is offline   Reply With Quote
Old 02-18-2013, 06:43 PM   #12
modding my tires made a night and day improvement. one of the most worthwhile mods that ive done. im also running the axle mounts flipped over and rear upper mount flipped over. springs are set to sit low
evan03 is offline   Reply With Quote
More crawl? - Similar Threads
tryina find people to crawl with and or places to crawl wraithscailer General Crawlers 3 12-02-2012 10:27 PM
July The 7th Coronado Crawl "Crawl of the Fortress" Docwolf Kansas 88 07-11-2012 03:47 PM
some where to crawl? toyotaguy8242 Washington 3 02-15-2011 10:17 PM
crawl abew330 Newbie General 4 01-16-2007 12:50 PM
