02-19-2013, 08:18 PM | #1 |
| was excited to have a all robinson tranny
when bolting the bottom gear to outputs i notice the gear is rubbing the mounting bolts hard core like keepping the bolts from going in so instead of clearanceing the robinson bottom gear to clear the bolts i decided to reef them on and hopeed it would be all tight enough to run true. offcourse that wasnt the case. the bottom gear wobbles pretty bad. its driveable but very noticable. i knew there had to be a reason robinson offerd the one peice botoom gear. ill be ordering it in a few weeks but in the meantime im hoping the idler and bottom gear kinda mate to eachother. pretty big bummer. its just one of those deals. i even put new bearings in the tranny thinkin it was them. also completly stripped and cleaned and still rough. when i orderd this gear i was thinking i should go one peice since i most likly wont waste money on metal vp case or run a dig. should listen to the voice in the back of your head allthough all would be fine if i cracked out the carbide burr soon as i noticed interfernce this is why i need metal gears this motor is 2000 plus watts and very torugey when i feed it voltage it seems to tear the tranny up Last edited by evan03; 02-19-2013 at 08:31 PM. |
02-20-2013, 09:41 AM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: Seattle
| Re: was excited to have a all robinson tranny
That's really weird, I'm pretty sure you're supposed to be able to run the non-one-piece RR gear.
02-20-2013, 10:21 AM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
I am buying the HR aluminum trans case so I can stuff my RR one piece bottom gear in it with the RR idler gear. I bought a VP case thinking, for some reason, the one piece bottom gear would work in it! I didn't do my homework so no one to blame. I have 3 Wraiths to use parts on anyway. I ordered the RR ones like you have now thinking I will do one trans that way with the plastic housing and see what happens. You should be able to run what you have there. I wonder if your reassembly isn't 100% correct? Is everything back the way it was? |
02-20-2013, 11:07 AM | #4 |
I dunno. Its all the same. Startn to wonder if my outputs bent. And maybe didn't notice with plastic gear Last edited by evan03; 02-20-2013 at 11:18 AM. |
02-20-2013, 11:43 AM | #5 |
Rock Stacker Join Date: Jan 2012 Location: McAdoo
I know its different than the wraith one piece gear but will the ax10 one piece gear work in the vp case?
02-20-2013, 11:59 AM | #6 | |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: was excited to have a all robinson tranny Quote:
02-20-2013, 04:10 PM | #7 |
you were right it is a wraith like no other, because it dosent run |
02-20-2013, 06:00 PM | #8 |
my gear only came with robinson stickers and no directions. but that sounds like is what i have going on. ive had it apart about a dozen times now and i cant tell a difrence in the gear my shoulda have got out the calibers to see. one side must be turned out alittle more to clear the 3 bolts. guess all take it down again and flip the gear over and see what happens thanks for the heads up ohhhh you gota be shitting me. i just looked and the directions where inbetween the two small sticker sheets. im not a sticker guy so i didnt mess with them. Last edited by evan03; 02-20-2013 at 06:02 PM. |
02-20-2013, 06:54 PM | #9 |
I had/have the same issue.. I didn't see any instructions either.. now I don't know where the stickers are. Crap! Been running for a few months without issues.. Post up how switching it around works.. |
02-20-2013, 07:34 PM | #10 |
i just switched it around and it seems quiter. and bolts cleard just fine. and you cant tell by looking at the gear that is difrent side to side. its like a hair width difrent. its one of those parts that is self explanitory but realy isnt and users who dont read the directions have 50 50 chanche of installing it correctly. glad im not the only one i was begining to think rpp was a peice of chit. turns out it was more me then them. but why not maching both sides the sames?? Last edited by evan03; 02-20-2013 at 07:39 PM. |
02-25-2013, 11:35 PM | #11 |
Rock Stacker Join Date: Feb 2013 Location: Apache Junction
i'm glad i came across this thread, i got the gear and the idler a few days ago and i'm planning on installing tomorrow...i'm not a sticker guy either so i probably would have never noticed the manual being hidden in there. Thanks for the thread!
02-26-2013, 05:51 AM | #12 |
| Re: was excited to have a all robinson tranny Since the VP case is made for the AX10 and uses only parts made for the AX10 yes yhe Ax10 1 piece gear will work in the AX10 VP case. The Wraith 1 piece gear will not.
was excited to have a all robinson tranny - Similar Threads | ||||
Excited Newb | jayross101 | Axial Wraith | 3 | 07-15-2012 02:27 PM |
Excited | asian195 | Chit Chat | 3 | 10-17-2011 11:00 PM |
just placed my order - I'm excited! | brianw | Axial SCX-10 | 12 | 03-30-2011 02:40 AM |
My first CR, excited! | Got_Demo | Tamiya CR-01 | 10 | 12-26-2010 09:09 PM |
