02-26-2013, 09:45 PM | #1 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Version 3.0 Axial Wraith
I've finally got around to rebuilding the Wraith and I have this in mind... make a serious rockbouncer! I've already purchased: Mamba Max Pro with 6900Kv system Savox SC-1256TG CC BEC Pro Right now I'm looking at swapping out the Wraith transmission for a AX/SCX10 transmission; Less to break and can handle more POWA!!! It looks like I need: AX/SCX10 Trans 32P Traxxas Spur and pinion RRP Gears Super Shafty outdrive extensions: AXIAL 6mm OUTPUTS (Extended) - Super Shafty 6mm Revo Driveshafts (Part numbers and how reliable are they?) Is there anything else I'm missing for the swap? Thanks! Last edited by Lentsnh2012; 02-27-2013 at 09:00 AM. |
02-26-2013, 10:09 PM | #2 |
| Re: Version 3.0 Axial Wraith
is 6900kv a typo? id run a 1230 before the the 1258 but if you already have the 58 then run it. i dont think id go higher then 4000kv you bought the 1258 for this? why? Last edited by evan03; 02-26-2013 at 10:11 PM. |
02-26-2013, 10:17 PM | #3 | |
| Re: Version 3.0 Axial Wraith Quote:
I'm glad you saw that!!! I bought the wrong servo! Whoops! Well I can put that servo in my JeepSpeed project and then buy the SC-1256TG for the Wraith, if it doesn't work out. | |
02-27-2013, 04:35 AM | #4 |
Higher KV doesn't always mean more power. You'll also lose a ton of torque with that high of a KV motor. I'd personally go with a 3300-4000 and keep some of the torque that the 8-10lb Wraith needs. Not to mention it will eat the bearings faster than you can install them, destroy the pinion support bearings and kill the lockers.
02-27-2013, 08:41 AM | #5 | |
The lockers, and axles will be replaced with Vanquish products. Anyway, Can we get this thread back on the Original Question? Thanks. I would like to order everything here soon. | |
02-27-2013, 08:46 AM | #6 |
Check out Haley's bullet proof Wraith thread.
02-27-2013, 08:56 AM | #7 |
| Re: Version 3.0 Axial Wraith |
02-27-2013, 09:18 AM | #8 |
Ok. Then yes there are things you're missing.
Version 3.0 Axial Wraith - Similar Threads | ||||
Wraith version 2.0, what would you like? | Pabust | Axial Wraith | 20 | 01-26-2013 03:08 AM |
