Thread: For those of you running a Pro4
Old 02-27-2013, 07:14 PM   #1
Default For those of you running a Pro4
I have read that a lot of yall are running a 12/54 setup in your rigs. I looked on the robinson racing website and the only 54 slipper set up I am finding is one for the slash. Is that what yall are running? or are you buying it with the 80t for the wraith and just buying the 54t replacement spur. Thanks in advance for the help
Crawl'n Cummins is offline   Reply With Quote
Old 02-27-2013, 07:18 PM   #2
Default Re: For those of you running a Pro4
I'm not sure about the 32p stuff. But have been running the 48p 80t RR for a while with no problems.
hatefulboy is offline   Reply With Quote
Old 02-27-2013, 07:31 PM   #3
running the gen3 80t with a pro4? what pinion?
Old 02-27-2013, 09:06 PM   #4
I run the Tekin Pro4 with a 14/54. the pinion is a Traxxas 14T hardened and the spur is a RR slash 4x4 54T metal gear/inner splipper. For that spur to work you Have to get the HD top shaft from Supershafty.com. Also I run RR gears in the tranny and CI (crawlerinnovations.com) lower chromoly outputs.
sullivanscx10 is offline   Reply With Quote
Old 02-27-2013, 09:09 PM   #5
14/56 here traxass pinion and duratrax spur. has held up to way more power then the wraith needs.
evan03 is offline   Reply With Quote
Old 02-28-2013, 07:21 AM   #6
Thanks y'all I appreciate it.
For those of you running a Pro4 - Similar Threads
Anyone running Pro4 4000kv? cjthing Axial Wraith 11 02-22-2013 05:00 PM
What ESC you running with your pro4? t3yf5g Axial Wraith 24 08-09-2012 09:09 PM
Ya'll running 35T motors, what pinion are you running? concretejungle Axial XR10 9 03-11-2012 08:18 PM
