03-14-2013, 07:51 PM | #1 |
| VP Currie front axle question
I am considering these for my Wraith. I would run the servo on the truss. I like the simplicity and strength of it. I know on the currie scx-10 axles there is interference issues with the servo on the axle. Is there the same issue with the Wraith or will it clear the chassis?? Stock chubs and knuckles, will they work with these axles? I am pretty sure I know that they do, I just want to make sure. If I were to get VP knuckles and chubs my VP tie rod will still work too then? I also read that these axles are 100% compatible with stock links, correct? |
03-28-2013, 01:03 AM | #2 |
Newbie Join Date: Apr 2012 Location: Newbern TN
| Re: VP Currie front axle question
I just put two front axels under mine and it worked ok. The only problem I've had has been the rear steer and my curry axel. You can't flip it like the stock so the drive shaft is in a bind. I put vp c-hubs and knuckles on mine but there shouldn't be any reason why you can't put stock on. Just make sure you have a nice supply of metal screw. I had trouble finding a small metal screw that wouldn't hit my axels themselves. All in all I love the look. Just a pain to get to the gears. I did have a problem with the servo plate mounting on top. You will need to chamfer one of the holes to get the screw to sit nice and flush on top of the truss, or buy the pan hard and servo relocation kit from vp. The first way is cheaper but the second looks so awesome. This has been some of the stuff I've fallen into. |
03-28-2013, 11:58 AM | #3 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
I just put a set on my dmg, I love the look, but it requires almost taking the axle half way or more apart to change the gears, very snug parts fitment. Loving mine though Sent from my SGH-T889 using Tapatalk 2 |
03-28-2013, 02:49 PM | #4 | |
I ended up finding out what I needed to and ordered these a while back. This thread had died originally without any responses. Quote:
09-04-2013, 01:55 PM | #5 |
Newbie Join Date: Jul 2013 Location: Corvallis
I drilled a relief in the axle truss to allow the servo mount to sit flush.
VP Currie front axle question - Similar Threads | ||||
First ever Leaf sprung Currie Axle | ScaleReady | General Crawlers | 14 | 02-10-2015 08:21 AM |
Currie axle... | Tbuck | Vaterra Twin Hammers | 3 | 03-13-2013 05:18 AM |
Front axle question... | Ghostrider304 | Axial SCX-10 | 3 | 11-28-2012 08:30 PM |
Front axle question... | Ghostrider304 | Axial AX-10 Scorpion | 2 | 11-27-2012 06:03 PM |
