11-27-2012, 05:39 PM | #1 |
Rock Stacker Join Date: Nov 2012 Location: The Show-Me-State
| Front axle question...
So I tried the search and nothing on this topic. So I've run the truck for a few days in my yard and at a local park. Started getting a bad squeak when running in either direction. So last night I took both axles apart and found the front axle was full of dirt and sand. Got it all cleaned out and packed with grease, but I think I figured out where the dirt was getting in. There are 4 unused holes in the top of the axle, 2 on each side of the diff. I took small screws and turned them in to fill them, ran the truck and seems to have clearance. Is this going to give me problems? Should I remove them? Seemed like a simple solution to my problem of the sand getting in, I know it won't help with water. Thanks for the help, Will- |
11-27-2012, 05:52 PM | #2 |
| Re: Front axle question...
I use 3mm setscrews for the same purpose. Bearing sets are cheap, sounds like you should invest in one. I run in water alot, so I drilled a hole in the axle case for another 3mm setscew. This hole allows me to visually inspect the ring gear, tighten the setscrews on my spool, and insert a needle fitting for my grease gun to "pack" the axles full of grease. Every few packs give them a few pumps till grease oozes out the pinion and axle ends. Keeps the bearings and gears happy. Also makes a mess, but I'm into that. Make double sure your new bolts aren't rubbing the axles. I think even a 3x6mm will rub if threaded all the way in. The setscews I use are only 3mm long. |
11-27-2012, 06:03 PM | #3 |
I used a 3x4mm screw. They are short. Will- |
Front axle question... - Similar Threads | ||||
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
LNC front axle teardown/axle shaft removal guide? | LowLock | Team Losi Comp Crawler | 1 | 05-22-2011 09:31 PM |
Quick front axle question | some87 | Team Losi Comp Crawler | 4 | 05-16-2010 10:45 PM |
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
A quick question about my front axle | cdl822 | HPI Wheely King | 4 | 09-07-2008 01:50 PM |
