03-22-2013, 08:24 AM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| 32p gearing
Probably a dumb question but what is the benefit of running 32p over the 48p? I have the timbuk2 setup and haven't had issues with it yet....
03-22-2013, 09:07 AM | #2 |
| Re: 32p gearing
Strength. You'll strip the 48p sooner or later. I've had both high torque brushed and brushless motors in my wraith and have only stripped 1 32p spur. I went through a half dozen 48p spurs in the first couple of months though.
03-22-2013, 10:06 AM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: 32p gearing
crawler nut is correct! That is the biggest reason to switch. Fatter teeth engage better and won't strip out as fast!! If you set the mesh correctly!
03-22-2013, 10:59 AM | #4 |
| Re: 32p gearing
Oh ok cool
03-22-2013, 02:04 PM | #5 |
| Re: 32p gearing Timbuk2 wraith edition has a 14mm rotor that pulls less than 200 amps on 2s so you may not need to step up to 32p stuff. If you don't need it I would stick with the quieter 48p gears.
03-22-2013, 06:07 PM | #6 |
| Re: 32p gearing
My 32P gears are nice and quiet. I run a plastic spur gear and RR Metal pinion. It is just as quiet as stock. I have the plastic cover on so it also helps keep it quiet in there. I am really happy with mine so far. |
03-22-2013, 07:23 PM | #7 |
| Re: 32p gearing Mine are pretty loud. I'm not running a cover though since I am using a 60t spur.
32p gearing - Similar Threads | ||||
Anybody switched to 32p yet? | heinie_21 | Vaterra Twin Hammers | 20 | 05-29-2013 11:40 AM |
32p vs. Stock Gearing. | Soulo747 | Axial Wraith | 13 | 07-02-2012 10:01 AM |
32p gearing | BlazinKreeper | Axial Wraith | 11 | 03-04-2012 10:32 AM |
32p spur | toka100 | Axial SCX-10 | 2 | 11-06-2011 06:36 PM |
32p gears? | devestator_x | HPI Wheely King | 2 | 09-03-2009 09:58 AM |
