03-26-2013, 03:39 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Front electronics box
Here's "da box" from the crawl space for anyone wondering what it looks like mounted. I can fit my Holmes Brxl, castle bec and spectrum 300 receiver and battery in it. The cross bar you see has to be replaced but I used a Dremel to make a little hole on each side of the box to replace it. Also used a Dremel to cut a little hole in the box to run the battery wires to the box. There is also a couple small braces that have to be cut off if you plan on running the cross bar with the box like I did. I'm currently running a proline rubicon body and it works great with this because the wiring and connectors from the box sit a little higher and so does the rubicon body instead of the stock hood which is pretty low and would be kinda tough to run a flat hinged hood IMO. The wiring is kind of a mess in the box because there isn't a whole lot of extra room but you don't see if anyway. All in all da box is great quality and fits perfect. |
03-26-2013, 03:41 PM | #2 |
| Re: Front electronics box
With battery
03-26-2013, 03:46 PM | #3 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
Great product, I've purchase 3 of them so far.
03-26-2013, 03:52 PM | #4 |
How is the material? It's ABS, right? Does it seem like it will hold up?
03-26-2013, 03:55 PM | #5 |
| Re: Front electronics box |
03-26-2013, 04:01 PM | #6 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
I read on TheCrawlSpace that its styrene. Thanks Cole for putting this up, I just ordered one. I am looking forward to having all my crap in one spot.
03-26-2013, 04:07 PM | #7 |
03-26-2013, 04:07 PM | #8 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: Front electronics box I avoided any holes so I could keep the water out. Closed cell foam under a stock hinged hood fits nice & tight & keeps water out. I have an AE-2, 2000mah 2s, CC BEC, rx & servo aux adapter wiring under there & I have room left. Nice & tough. I would guess PVC as far as a material. |
03-26-2013, 04:09 PM | #9 |
I don't run in water so I didn't worry about a few holes.
03-26-2013, 04:38 PM | #10 |
Pebble Pounder Join Date: Apr 2006 Location: Spring Hill, TN
Couldn't decide which way I wanted to go so I bought the front, rear and the lid. I'm basically putting the battery up front and the ESC and RX in the rear.
03-26-2013, 04:58 PM | #11 |
Quarry Creeper Join Date: Nov 2012 Location: oshkosh
03-27-2013, 12:11 AM | #12 |
Newbie Join Date: Aug 2012 Location: sooke
Ok, where can I get a couple of these?
03-27-2013, 12:13 AM | #13 |
Nevermind... Idiot,(slap forehead)!
03-27-2013, 08:28 AM | #14 |
Rock Stacker Join Date: Jan 2013 Location: Casper
I left the cross brace out of mine which seem to get it down a little lower, then I just bolted it to the frame. It's solid as a rock.
03-27-2013, 08:56 PM | #15 |
Newbie Join Date: Feb 2010 Location: Tullahoma Tn
03-27-2013, 10:21 PM | #16 |
Yes sir, but it's a little tight.
03-28-2013, 12:24 AM | #17 |
03-28-2013, 11:01 AM | #18 |
Just ordered myself one, playing the waiting game now...
03-28-2013, 11:47 AM | #19 |
I'm gonna order a rear one with cover tonight. Then I can put my brxl, bec and receiver in the rear so its not so cramped up front with all the wires
03-28-2013, 07:37 PM | #20 |
Are you going to change you your in the rear at all??
Front electronics box - Similar Threads | ||||
Wraith Electronics box | The Crawl Space | Chassis and Suspension | 562 | 02-15-2021 12:18 PM |
Front electronics box | throttlejock27 | Axial Wraith | 4 | 01-28-2013 11:23 AM |
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
Electronics box | SC Convert | Axial Wraith | 20 | 06-18-2011 03:16 PM |
box for electronics | silverbullet | Electronics | 5 | 04-05-2006 06:52 AM |
