03-31-2013, 08:02 PM | #1 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Axial Wraith vs Savox TG servo
Wraith won :( I asked Savox about the warranty (it's only 2 months old), but I just went ahead and bought the gear set. HOPEFULLY this is all I'll need and not another $70 servo. Has anyone had an indestructible TG servo? This Savox did great but I'm tired of breaking servos. |
04-01-2013, 02:26 PM | #2 |
Rock Stacker Join Date: Mar 2013 Location: Newmarket
| Re: Axial Wraith vs Savox TG servo
If you are tired of breaking servo's I would build in a weak point before the servo. I have left the stock wraith tie rod and drag link just to serve as a fuse. If I do something dumb and force it when I shouldn't the stock plastic will give instead of putting all the force on the servo gears. If I was going to keep the wraith front end I would consider a metal tie rod and a plastic drag link.
04-01-2013, 02:41 PM | #3 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
A lot of the guys run Hitec Servo's. I use a Hitec HS 7955 TG a little on the spendy side but it has held up to whatever I can wedge my wraith into. |
04-01-2013, 07:58 PM | #4 | |
| Re: Axial Wraith vs Savox TG servo Quote:
I might have to give that one a whirl. I thought the Savox could stand up to my abuse. As I was reading about the gear set before I bought it, I found out that it still uses an aluminum first gear!! I believe that is what I broke too. I might have to bite the bullet and get what is already tried and true, a Hitec HS-7955TG. | |
04-01-2013, 08:46 PM | #5 |
I definitely agree that they will stretch over time. Mine are starting to do so with my savox 1230sg tugging on it. As my friend once told me "when you upgrade to a stronger part all you are doing is moving the breaking point." If you build in you breaking points then theoretically you should be less surprised when something happens and spend less time waiting on parts. I think I would like to try a plastic drag link with revo ends, but since I'm working on collecting parts for an exo front suspension swap it probably won't happen. |
04-02-2013, 01:42 AM | #6 |
Newbie Join Date: Dec 2011 Location: usa
This might sound stupid,, but how about a "servo saver" ?????
04-02-2013, 11:16 AM | #7 |
If you have a CMS then I could see possibly running a servo saver. I can't say that I would like to look of one hanging off the front of my axle.
04-02-2013, 01:01 PM | #8 |
Pebble Pounder Join Date: Oct 2011 Location: SLC
I did the same thing to my TG savox, the top gear stripped. I cant remember the model # but it was around 70 dollars. Then i bought the 100 dollar savox and havent had an issue with more abuse. Hitec is the way to go IMO
04-02-2013, 02:45 PM | #9 | |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
Sent from my iPhone 5 using Tapatalk | |
04-02-2013, 03:41 PM | #10 | |
Pebble Pounder Join Date: Dec 2010 Location: UK
I kept the plastic links on mine running a Savox 1256 tg and after well over a year I've had no issues. | |
04-02-2013, 04:04 PM | #11 |
Newbie Join Date: Sep 2012 Location: Thornton
I run a Hitec 7950TH on weighted VP wheels with no issues. It's spendy, but it's a boss. It gets a little warm (not hot), but that's about it. 486 on 7.4v http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWCE6 Last edited by Swass; 04-02-2013 at 04:08 PM. |
04-02-2013, 04:30 PM | #12 |
I jump and rock bounce my wraith pretty hard with a 7955 without issue but I still have the stock plastic linkage. I'm kind of scared to swap to metal linkage.
04-02-2013, 05:20 PM | #13 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
What did you do to break it? Force on rocks? Hard landing? I had a new Savox go out on a Losi buggy. Just stopped working. Savox replaced it, no questions asked. They said as long as it didn't failure due to fuel (nitro). |
04-02-2013, 07:17 PM | #14 | ||||||
I'm still awaiting Savox's response as well as Savox's replacement gear set I purchased. | ||||||
04-02-2013, 09:53 PM | #15 |
What model savox are we talking about here? I have the 1268 and its a lot more servo the the 1257 size power seed everything. I don't think the 1250 series was realy meant for crawlers |
04-02-2013, 09:57 PM | #16 |
| Re: Axial Wraith vs Savox TG servo |
04-02-2013, 10:10 PM | #17 |
An airplane servo ;) The 1256 does have 277oz so can get the job done crawling. Last edited by evan03; 04-02-2013 at 10:16 PM. |
04-02-2013, 10:27 PM | #18 |
RCC Addict Join Date: Oct 2012 Location: Norcal
SA-1230sg has been a monster on my front end, never a glitch either. 500 oz.
04-02-2013, 10:45 PM | #19 | |
Rock Stacker Join Date: Feb 2013 Location: Apache Junction
I've been running this one for a while as well. I have a CC BEC too. Not a single issue with it. Savox SA1230SG Digital Servo | |
04-03-2013, 03:26 PM | #20 | |||
I just installed the new gear set and the Savox is back up and running! The $25 gear set sure beats a new servo!!! I will get the Hitec 7955TG anyway so that this doesn't happen again. Here's what I found when I cracked open the case: | |||
Axial Wraith vs Savox TG servo - Similar Threads | ||||
Savox servo | Bogncrawl | Electronics | 8 | 02-17-2013 08:25 PM |
Savox servo? | sandrocks | Electronics | 3 | 11-20-2012 03:01 AM |
savox servo | weese78 | RC4WD Bully | 5 | 01-22-2011 12:33 PM |
