04-01-2013, 02:33 AM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: yucca valley,
| converting my crest to wraith!!! help please!
ok i have the wraith cage and body! realized skidplate was different have that on the way. now worried about tranny? am i gonna have to buy a new one. ill be $80 in the converson after skidplate and even more if i need a tranny? any answers , solutions or anything i need please let me know thank you very much!
04-01-2013, 02:49 AM | #2 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: converting my crest to wraith!!! help please!
I'm not sure what trans the ridge uses, but I don't think you'll have a problem, I'm using a AX10/SCX10 trans in my wraith. |
04-01-2013, 03:09 AM | #3 | |
| Re: converting my crest to wraith!!! help please! Quote:
Axial Racing AX30437 Dig Lockout shaft Last edited by puffntough760; 04-01-2013 at 03:18 AM. | |
04-01-2013, 03:18 AM | #4 |
duh your using ax10 too lol! works no prob?
04-01-2013, 03:37 AM | #5 |
No probs for me but, I have a mixture of parts. Junfac shafts Wheely King diffs AX10/SCX10 trans 1.9's etc |
04-01-2013, 03:41 AM | #6 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
| Re: converting my crest to wraith!!! help please! "PHANTASMAGORIA" by DRV KRAWLER This guy used the Crawler Innovations output extensions to make his tranny longer, which is the biggest difference in the Ridge/ Wraith tranny. You could use the Ridge tranny as is, but your rear driveshaft won't be engaged very well. Keep in mind that the Wraith is an inch or more longer. |
04-01-2013, 11:44 AM | #7 | |
that'll work but for fifty bucks i could just buy the wraith tranny. the ax30437 wont work? thanks for the input fellas keep it comin! | |
04-01-2013, 11:53 PM | #8 |
found out what im doin! k for know im im slappin this s+it together but i have two weeks to get my converson done. xl-5 esc, cross terminaled fried stock esc. reedy radon 17t motor on its way paddles, and this 48 Pitch - 5mm E-Maxx Drive Shaft Upgrade Kit for Wraith http://www.crawlerinnovations.com/im...obile.jpg.have vxl system but depending on instalment because of steel robinson gears in budget not sure if thats a smart idea
04-10-2013, 01:00 AM | #9 |
this is wut i did; ok got everything put together. besides skid plate axial part numbers axa187 set screws and button head screws were needed. used ax10 tranny and driveshafts didnt meet at all well. i took two female driveshafts and mounted them to both sides and used two spine shafts and took one and cut into two shoving both small halfts down into the female ends so the bigger spine shaft sits in the middle without sliding down into the iether female shafts causing the assembly to come apart. so you need two spine shafts one cut into tw0 bout 1/2" and the other spine shaft cut approx 1" and two females. see here broke in reedy radon motor water method style with xl5 esc. mounted in wraith then experienced overheating and smelled burnt after the first 2 initial runs after 5 min of run time. let it cool then last run of the day i putted it around climbing thehome made course. stayed cool and lasted the whole batt no serious motor temps. (touchable). weird huh? looked athe motor pinion is spinning counterclock wise diffs are'nt reversed. so thats not overheating it. |
converting my crest to wraith!!! help please! - Similar Threads | ||||
Rednecks Rampage Ridge Crest Build! | redneckrampage | Axial AX10 2nd-gen | 10 | 01-27-2013 10:03 PM |
Axial ax10 r.crest jeep trail ride | SKOTTIE.B | 2.2 Scale Rigs | 1 | 07-22-2012 07:15 AM |
Vegas Crawlerz Gold Crest park | sean_lv_crawler | Videos! | 0 | 06-16-2005 11:43 AM |
Vegas Crawlers GOld Crest Vid | sean_lv_crawler | Videos! | 0 | 06-07-2005 07:06 AM |
