04-14-2013, 04:41 PM | #1 |
Newbie Join Date: Sep 2012 Location: Trumbull, CT
| Noisy transmission
Anybody have issues with a noisy transmission? From the looks of it the top shaft looks to be flexing under a load causing this. You can wiggle the spir gear slightly by hand. I don't know if its a bearing, a bad trans housing or what.
04-14-2013, 05:53 PM | #2 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
| Re: Noisy transmission
Tear it down!
04-14-2013, 05:58 PM | #3 |
I failed to mention that I did year it down. No gears seem to be stripped, no cracked case, the bearings looked fine. I guess the question is. Could the bearing lose tolerance and make the top shaft walk around?
04-14-2013, 06:02 PM | #4 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
Yes it could, did you slide the bearing on the shaft and see if there was any movement.
04-14-2013, 06:23 PM | #5 |
Good point. I didn't check for play in the bearings. Just basically looked to see if they were rusty and in one piece.
04-15-2013, 05:36 PM | #6 |
Newbie Join Date: Mar 2013 Location: Central city
Should also inspect the housing closely where the bearing press in the could be out of tolerance
04-18-2013, 04:47 AM | #7 |
New Fast Freddie's bearing should be hear by the weekend. I'll inspect everything when it's apart and report my findings.
04-18-2013, 05:08 AM | #8 |
Rock Stacker Join Date: Jan 2006 Location: Okinawa, Japan
Mine was making noise a while back. In the end I found that is was just housing screws being loose
04-18-2013, 10:40 AM | #9 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
if you take a bearing out, put your finger over the hole and push while rotating the outer bearing ring, you'll feel grinding, dirt, rust, whatever wear is in there. If its smooth, try another bearing. Another thing to check is make sure all 3 screws that hold the output shafts to the bottom gear are tight. lastly, make sure there is no missing teeth on the ring and pinion gears and the mesh isnt too tight or one of the gears is running on the case or cover |
04-21-2013, 09:32 AM | #10 |
Fix!! Nice and smooth now. The bearings in middle gear in the trans sounded gritty and one bearing on the top shaft. Thanks
04-21-2013, 11:13 AM | #11 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
Its gonna be first bearing behind the spur needs replacement.
Noisy transmission - Similar Threads | ||||
noisy servo | WrecknRox | Newbie General | 11 | 02-21-2011 12:27 AM |
Noisy R2 tranny? | Phylodog | Newbie General | 11 | 12-02-2009 01:12 PM |
Noisy pinion? | LincolnBlack | EnRoute Berg | 14 | 01-09-2009 06:52 PM |
Noisy servo? | Mortimer Snerd | Electronics | 4 | 07-20-2008 03:51 PM |
noisy axles | marzzz23 | Tamiya TLT Crawlers | 14 | 05-12-2007 10:13 PM |
