04-19-2013, 07:15 PM | #1 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
| Tekin 13.5 Gen 2 gearing, Ideas welcome
Hey guys, Just set up my Wraith for a 13.5 gen 2 motor. Wraith weighs, 10lb 1 oz(heavy) Built to hilt axles, trans, driveshafts BGR goodies everywhere. ESC: Mamba max pro Battery: 5000mah, 3 cell Current gearing is 14/56 32 pitch gears. I took her out on a maiden voyage today and she is quick, but the crawling leaves a bit to be desired. I am kicking around two ideas of the gearing. GO to a 60/14 for a ratio of 4.29 or the 56/13 for a ratio of 4.31 Or should i go deeper as I don't need all this top speed she has? What have you guys found works for a hot motor and heavy rig. |
04-19-2013, 07:26 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Tekin 13.5 Gen 2 gearing, Ideas welcome
IDK if I can help but mine weighs 7.85 lbs. I run 48P gears...14/93 with a Fantom Racing 7.5T pro mod race motor controlled by a BHR 120A LT4 esc on 3s. Just finished it a few hours ago and did a half ass test in the living room. It turns those tires pretty slow. Thinking about swapping out the axle gears for the 43/16's.
04-19-2013, 07:54 PM | #3 |
I think that your setup is a bit too different from mine, they always run well in the house, out on the trail is where the faults really come out. That 7.5 is a super hot motor. Your gearing is off even for that motor. It comes out to 6.64:1. Gearing your truck closer to 4.5:1 or even 5:1 will fix your issues. Try running a 86/17 setup It will put you at 5.05:1
04-19-2013, 09:16 PM | #4 |
I joined the Band! Join Date: Dec 2010 Location: Usa
I run a 4600kv for snow bashing and do well with 56/12.
04-19-2013, 10:29 PM | #5 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
DEEPER Much DEEPER.. You need to get that ratio more towards 6 to 1... Right now I am running 15-90 on my SCX scaler (about 9 lbs), with a 13.5 Redline, on 3s. Motor runs great, decent speed, crawls GREAT. And I can crawl it HARD and keep the motor in safe temps. Get yourself a temp gun and check that motor. I bet after 5 minutes of running, you are getting that motor prettyhot... Good luck.. |
04-19-2013, 10:39 PM | #6 |
I'm running a 3400kv 4 pole with 11/60. It's perfect imo.
04-20-2013, 01:04 AM | #7 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
Im running a tekin 13.5t as well and with 12/56 gearing on 3s i find it a little too fast for slow technical crawling. Im dropping to 10/56 and ill probably leave it there
04-20-2013, 06:52 AM | #8 | |
| Re: Tekin 13.5 Gen 2 gearing, Ideas welcome Quote:
05-23-2013, 10:28 PM | #9 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Hello, I have almost the same question. My wraith ways about 7 pounds, it has full steal Robertson Racing trans. gears , and the idler gear. Full titanium (custom) driveshafts, vanquish steering knuckles, c-hubs, lockouts, and all links are titanium. I have the tekin rs with a 13.5 turn and my gearing is set to 87/20, is that to high for what I am running. also to let you know that I just bought a new 3s 5000mah 50c battery, and ordering a new tekin gen 2 10.5 turn , now is this to powerful of a motor for this truck, the gearing, and the esc? Is the esc capable of handling this much wait? And my temps are ok now but can I connect a fan to the esc soldering tabs so it stays cool? Just let me know if this to much motor/power, and yes I am putting a new 17 t pinion on it should this work with the 87 tooth spur? If anyone could tell me if I am doing this right let me know thank you I appreciate the help.
05-24-2013, 06:04 AM | #10 |
An update on my setup: Swapped out the 7.5T 5000Kv sensored motor for a 13.5T 2850Kv sensored motor, changed out the original ring/pinions for 43/13's, and 93/14 spur/pinion. Tires are 5.5". On 2s, crawls beautiful yet top speed sucks. On 3s, top speed is great yet crawling suffers. So now I have ordered a 21.5T 1600Kv sensored motor which should be here next week and we'll see how that one does. But ultimately, how it runs is what i'll live with. This will be motor #7 that iv'e tried in this thing to attempt to get the best of both worlds of crawling ability and decent speed.
05-24-2013, 06:12 AM | #11 | |
05-26-2013, 05:53 AM | #12 |
| Re: Tekin 13.5 Gen 2 gearing, Ideas welcome |
05-26-2013, 08:54 AM | #13 |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
10/56 here. My rig is smooth when crawling and still has nice speed. It's not super fast but fast enough for me. |
05-26-2013, 02:35 PM | #14 |
| Re: Tekin 13.5 Gen 2 gearing, Ideas welcome I don't. I will take some video next time I get a chance. I have been meaning to for a while now. It's not comp crawler smooth but it it crawls plenty slow for scale/g6 style fun.
05-26-2013, 02:37 PM | #15 |
07-21-2014, 11:30 AM | #16 |
Pebble Pounder Join Date: May 2013 Location: Nobleboro
07-21-2014, 05:50 PM | #17 |
Newbie Join Date: Dec 2012 Location: Auburn
Im running a 13.5 gen two with rs pro gen 2, the fix for mine to crawl I put a rc 4wd two speed trans. super fast in hi range crawls almost as good as my moa crawler in lo range.
09-02-2014, 11:33 AM | #18 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
13.5 Gen1 should be arriving in the mail today. HOping to have it installed on an RC4WD 2 speed tonight powered by MMP. I know i'll swap pinions around, but should i start around 5:1 or go deeper and closer to 6:1 for the spur/pinion combo? It's OD up front and stock gearing in rear axle Thanks in advance!!! |
Tekin 13.5 Gen 2 gearing, Ideas welcome - Similar Threads | ||||
tekin pro4 gearing | guidetti_angelo | Axial Wraith | 57 | 03-22-2013 08:38 AM |
