06-06-2013, 07:59 PM | #1 |
Pebble Pounder Join Date: Sep 2011 Location: Between the thoughts of yesterday and the ideas of tomorrow
| Spring help
I have the 4" losi comp shocks on all 4 corners of my wraith. They still have the white springs and my rig in weighing in around 8.5 lbs. What spring color should I be running to help give it a little more height. THanks |
06-07-2013, 06:56 AM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Spring help
Unless your springs are seriously compressing from the weight of your rig, a longer shock/spring set will get you more height, not just changing the spring. Another option is to get a shock lowering kit and simply mount it upside down. In that configuration, you can raise the ride height without having to change shocks.
06-07-2013, 03:41 PM | #3 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Spring help
or put some pre load on them
Spring help - Similar Threads | ||||
Internal spring/ and stock spring set up | wassaakk | Newbie General | 7 | 06-06-2010 06:53 PM |
MNRCRC Spring Fling Spring/Summer series comp #1 | freetimecrawler | Minnesota | 8 | 04-19-2010 04:40 PM |
MNRCRC Spring Fling Spring/Summer season opener | freetimecrawler | Minnesota | 33 | 04-19-2009 08:00 PM |
MNRCRC Spring Fling Spring/Summer season opener | freetimecrawler | Competitions | 0 | 04-05-2009 01:16 AM |
MNRCRC Spring Fling Spring/Summer season opener | freetimecrawler | Minnesota | 31 | 04-06-2008 11:27 PM |
