06-17-2013, 07:36 PM | #1 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
| over heating?
so I was playin with my wraith today and my motor was so hot I couldn't touch it. I don't understand how it is over heating. My current set up is: HH brxl esc HH 35t expert motor 2s lipo 5000mah spur is 80t pinion is 17t I think my gearing is fine but I could be wrong. my only guess is that the motor needs a rebuild. I've been using the motor for 6 months now. That is all I can really think of. Also my gear mesh is fine and I have not added any wheel weights. Let me know what you guys think. Thanks shayn Last edited by ka1fornia; 06-17-2013 at 07:40 PM. |
06-17-2013, 07:59 PM | #2 |
Rock Stacker Join Date: Mar 2013 Location: Chesapeake
| Re: over heating?
There going to ask, what kind of wheeling are you doing? Crawling, trails, mud, etc.
06-17-2013, 08:05 PM | #3 |
| Re: over heating?
Seeing as it only goes about 4mph max speed it's mostly crawling but I do trailing as well. I'm thinking because it only goes 4mph when I am trailing or trying to hill climb a little the motor is at max rpm for so long because it's so slow...
06-17-2013, 08:09 PM | #4 |
| Re: over heating?
I just ordered an 87/15 and I will be running the stock motor for now. I am curious to see how slow it is going to be.
06-17-2013, 08:12 PM | #5 |
| Re: over heating?
that is going to be pretty slow, before i bought the HH 35T expert i was running the stock 20 on 80/17 and it was probably about 5-6mph. your gear ratio will be higher though so will be slower. It's awesome for crawling but i'm a little tired of the slow speed now...been running this set up for 6 months or so now...maybe longer
06-17-2013, 08:21 PM | #6 |
| Re: over heating?
Yea, I figured it would be real low. I over heated my motor doing some crawling the other day , so I figured I would get some crawling gears and play around. I can also see how the 80/15 combo does, 80/20 is just to high for what I like. |
06-18-2013, 05:40 PM | #7 | |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
| Re: over heating? Quote:
I run those motors in 3 of my scalers and they usually last 2-3 summers before needing a rebuild and I subject them to a little water every now and then. | |
06-18-2013, 05:54 PM | #8 | |
over heating? - Similar Threads | ||||
servo over heating | vegas1973 | Electronics | 1 | 02-20-2011 06:15 PM |
battery heating up | crawlerjr | Electronics | 1 | 12-26-2009 09:58 PM |
Garage Heating | pigeonfarmboy | Tools, and Procedures | 34 | 12-12-2009 01:09 AM |
Over heating Way to much | killerflexhpi | HPI Wheely King | 1 | 09-25-2008 10:13 AM |
motor heating up | bipolarcrawler | Traxxas Crawlers | 4 | 08-24-2005 02:16 PM |
