06-18-2013, 08:49 AM | #1 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
| Shims to help backlash?
Putting a warith together and looking for the shims to go around the pinion to help save my overdrive gears. Thanks for the help.
06-18-2013, 09:00 AM | #2 |
| Re: Shims to help backlash?
I've used some washers or whatever I have around that is roughly the same diameter.
06-18-2013, 09:09 AM | #3 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
5mm shims should do it, lots of companies make em, Losi, Tamiya, HPI to name a few, i did not have to shim mine when i swapped gears, might depend on the bushings/bearings you have in there.
06-18-2013, 09:19 AM | #4 |
| Re: Shims to help backlash? I know that hpi makes some just don't know part number. So was seeing if someone out there might know the part number. Thanks for the help and info.
06-18-2013, 09:25 AM | #5 | |
| Re: Shims to help backlash? Quote:
Losi LOSA6356 Tamiya 53587 Hot Bodies/HPI HBS66263 | |
06-18-2013, 10:18 AM | #6 | |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
| Re: Shims to help backlash? Quote: | |
06-18-2013, 01:37 PM | #7 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
i use these, work great! Team Durango 5x7x0.2mm Distance Shim Set (10) [TDR709015] | Hardware & Fasteners - A Main Hobbies installed 2 frt and rear on the outside so the pinion gear couldnt go back in. Tried one on the inside but it was way to tight. |
06-18-2013, 02:13 PM | #8 |
Fast Eddy |
07-09-2013, 01:53 AM | #9 |
Newbie Join Date: Dec 2011 Location: Alexander
Would using these shims help with the pinion pushing the bearing out?
Shims to help backlash? - Similar Threads | ||||
shims? | aircooled67 | Tamiya Txt-1 and Juggernaut | 1 | 03-26-2010 03:03 PM |
shims | mesooners | Team Losi Comp Crawler | 10 | 09-11-2009 10:14 PM |
shims | mesooners | Team Losi Comp Crawler | 11 | 08-29-2009 08:54 PM |
axial zero backlash gears | Ty | Axial AX-10 Scorpion | 9 | 07-10-2009 06:27 AM |
