Thread: 2 speed wraith build
Old 06-24-2013, 11:59 PM   #1
Default 2 speed wraith build
So all the parts showed up, minus the aluminum steering arm, tonight I've installed the RC4WD AX2 2 speed transmission, 10 piece Blue Monkey Titanium arm set, MIP driveshafts, LRP Vector X11 sensored motor, and a Savox SA-1231SG steering servo.
Still have to install a shift servo, going to go with a traxxas 2080 mini servo, or something similar, this way the shifters on the interior won't have to be removed, I took the transmission to do a quality control check, heard a few horror stories with bad assembly, mine was perfect, just added a little thixo grease and assembled it.
[IMG] photo photo1_zps5f04be4c.jpg[/IMG]
[IMG] photo photo4_zpscbf3ebdc.jpg[/IMG]
[IMG] photo photo5_zps845541dd.jpg[/IMG]
[IMG] photo photo3_zps8be3e0e8.jpg[/IMG]
imcochrane is offline   Reply With Quote
Old 06-25-2013, 08:30 AM   #2
Default Re: 2 speed wraith build
looking good
bikeboy is offline   Reply With Quote
Old 05-09-2014, 06:24 PM   #3
How did the 2080 servo work out?
SynisteR6 is offline   Reply With Quote
Old 02-05-2016, 07:14 AM   #4
So I'm wanting to get a 2 speed for my wraith. But I can't find a definite answer as to if I need to buy shorter drive shafts. Can you help me out? I don't know how to shorten the stock shafts so I'd rather buy new ones if I need to.
geargrabber5 is offline   Reply With Quote
Old 02-05-2016, 08:08 AM   #5
You do not need new shafts, AX2 uses the same length as stock.
mikebecher is offline   Reply With Quote
Old 02-05-2016, 08:10 AM   #6
Awesome thank you! Ordering one today.
2 speed wraith build - Similar Threads
Wraith 2 speed Spur gear Jacksprogis Axial Wraith 3 03-24-2013 02:20 PM
2-speed wraith suzuki Axial Wraith 1 09-11-2011 09:21 PM
Wraith Speed Problems!! WarTrader Axial Wraith 12 08-29-2011 10:59 AM
