07-16-2013, 04:11 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
| Wrexo question
I'm going to be building a wrexo soon and was wondering If i could run the rc4wd arb diff cover and be able to flip the gears in the exo front end so it will work. Dose anybody know or do I need to pick a new diff cover? Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
07-16-2013, 04:26 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
| Re: Wrexo question
You won't be able to flip the ring gear in the front of the EXO because there is a cut out in the chassis for ring gear clearance. You would have to machine the chassis away on the opposite side in order for the gear to clear. You can see the offset cut outs front and rear in this photo. TowerHobbies.com | Axial Main Chassis Plate Aluminum 4mm Black EXO |
07-16-2013, 04:30 PM | #3 |
Thanks a lot man. I may try it. I'm building a custom Chassis so I would have to make a cut out anyways. Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
Wrexo question - Similar Threads | ||||
silverado wrexo | HillbillyCrawler | Axial Wraith | 42 | 07-23-2014 03:54 AM |
Mad Skinz Wrexo Wrangler Build | scottanthony | Axial Wraith | 86 | 03-09-2014 10:49 PM |
Antisimplistic's Wrexo build... | Antisimplistic | Axial Wraith | 5 | 05-29-2013 06:48 PM |
