Thread: Trouble with vanquish steering knuckle
Old 07-20-2013, 12:44 AM   #1
Default Trouble with vanquish steering knuckle
Can not get bearing to seat, the bearing is flush but will go no futher.
nedaroth is offline   Reply With Quote
Old 07-20-2013, 06:22 AM   #2
Can you post a pic? The bearings sit a little cockeyed in those knuckles due to the king pin inclination...
JeremyH is offline   Reply With Quote
Old 07-20-2013, 09:46 AM   #3
Default Re: Trouble with vanquish steering knuckle
Hi Jeremy thanks for your response, I tried to post pic with no luck. Somehow I installed these on my Poison Spider RTR with no problem also one side of this wraith kit. Right now the bearing is sitting flush, I can not pop it out at this point so needless to say the build as come to a halt.
Thanks for any help.
Old 07-20-2013, 10:14 AM   #4
Take the bearing out of the knuckle. Put the bearing onto your steering axle shaft, universal, VVD whatever you're using to steer with. Then pull the shaft through the knuckle...it should help you seat the bearing properly. Pull the steering shaft out and check the bearing before moving further.
chicklet is offline   Reply With Quote
Trouble with vanquish steering knuckle - Similar Threads
XR steering trouble shooting Curcal Axial XR10 4 06-08-2012 12:05 PM
Vanquish Wraith C-Hub & Steering knuckle Video Review & Install FastEddy Axial Wraith 0 10-28-2011 01:04 PM
inside tyre touches steering knuckle / steering linkage murky123 Axial SCX-10 4 10-06-2010 04:46 PM
First Project and steering trouble Brandon502 Electronics 3 09-03-2005 06:56 PM
