09-01-2013, 06:33 PM | #1 |
Pebble Pounder Join Date: Aug 2012 Location: repentigny qc
| wmax99 wrexo projet
ok starting whit my old exo and whit spare wraith parts ;) combo xerum 3656sd 4700kv 4pole sensored exo parts front cvd exo front metal 100mm shock hr strc knuckle strc shock tower strc steering hitec 7954sg rc4wd ax2 2speed tranny mip drive shaft fast eddy beering kit 38/13 bevel hd gears blue monkey upper rear link vp 1/4 lower rear link stock wrauth rear plastic diff :( oitbull rbII tire on hr metal weels [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
09-01-2013, 08:25 PM | #2 |
RCC Addict Join Date: Dec 2012 Location: Crookston
| Re: wmax99 wrexo projet
Looking good so far.
10-04-2013, 07:37 PM | #3 |
i finaly finich it its alive now running great just need the front locker now [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] lil hill climb 010_zps832d0722.mp4 Video by wmax00 | Photobucket hill climb 2 011_zps5d4a8ca7.mp4 Video by wmax00 | Photobucket lil jump 030_zps2a2978da.mp4 Video by wmax00 | Photobucket |
10-04-2013, 07:42 PM | #4 |
Looks good. Nice work
10-05-2013, 08:37 PM | #5 |
| Re: wmax99 wrexo projet |
10-05-2013, 09:00 PM | #6 |
Nice
10-09-2013, 01:04 AM | #7 |
i have ordered all the stuff for make the front axle locked and the mip cvd conversion + some team durango shock for the front il put the powerstroke in the rear more i run this truck more i like it and wonder if il keep my vp wraith ;) |
10-09-2013, 04:01 AM | #9 |
no probleme there for now i already run exo cvd ;) 106mm and yes il beef it up for whit mip cvd for slash and il use the grip fab locker
12-05-2013, 12:29 PM | #10 |
12-05-2013, 01:20 PM | #11 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Awesome front diff solution. I dont trust myself to get it centered correctly. Knowing my luck, I would miss the mark and "Grenade" some gears!
12-05-2013, 01:22 PM | #12 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Huh, that looks familiar lol |
12-05-2013, 02:04 PM | #13 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
nice work so far !! make sure that the front locker shaft your using is super hard metal, if its just a standard steel (hot or cold roll steel rod), it will bend/brake fairly fast ! just helping out ! |
12-05-2013, 02:23 PM | #14 |
thx for tips i did use stainless steel so shud be gd ;)
12-05-2013, 04:15 PM | #15 |
| Re: wmax99 wrexo projet better be looking for a replacement, stainless steel - its not vary hard !! its going to brake @ where you drilled the pass thru holes for the pins. not trying to say it will not work 4 you - it will - for a wile !! its A - I've already been there & done/tried that thing ! Ive been thru a few locker shafts now, & ended up using a alan wrench for a locker shaft with no pass thru pin holes, grub screws on both sides of the MIP drive hub on the flat sides of the alan wrench. it seems where the holes are drilled in the shaft, is where they have failed - every time so no more holes ! this one has been holding up/working the best 4 me - so far ! trying to help !! |
12-05-2013, 06:10 PM | #16 |
ok u did get me wrong ;) i apreciate tips ;) il have to try whit a 5mm alen key ;) its kinda a easyer way to im french so sometime i dont use gd words ;) |
wmax99 wrexo projet - Similar Threads | ||||
wmax99 vp wraith | wmax99 | Axial Wraith | 12 | 07-08-2013 10:28 PM |
wmax99 wraith projet | wmax99 | Axial Wraith | 11 | 09-06-2012 02:01 PM |
My Berg projet | TotoRax | EnRoute Berg | 35 | 01-09-2011 04:07 AM |
projet track now very big, many friends | sonat | Losi Micro-Rock Crawler | 16 | 11-07-2010 11:44 AM |
