09-02-2013, 04:32 PM | #1 |
Pebble Pounder Join Date: May 2012 Location: California
| 5" VP Rigid Light bar ?
Any suggestions on mounting this below the front roof line? Thanks |
09-02-2013, 04:44 PM | #2 |
Pebble Pounder Join Date: Feb 2013 Location: El Dorado Hills
| Re: 5" VP Rigid Light bar ?
I drilled 2 small pilot holes into the stock plastic windshield cage, used 2 3mm self threading kit screws for mounting. |
09-02-2013, 05:14 PM | #3 |
Newbie Join Date: Jan 2007 Location: Bronx
| Re: 5" VP Rigid Light bar ? |
09-02-2013, 07:34 PM | #4 |
Pebble Pounder Join Date: Feb 2013 Location: Florida
It just takes about 15 minutes with a little chunk of aluminum and a file to build a couple of brackets. Mine utilize the frame screws at the top of the frame. They are actually kicked up a bit in this photo, but normally they sit flush with the roofline. The mount right below the frame screw has a tab that is bent under the roof frame to keep them from slipping down too low. |
5" VP Rigid Light bar ? - Similar Threads | ||||
VP Rigid light bar question | sgtlopez79 | Vaterra Twin Hammers | 3 | 05-04-2013 09:17 AM |
Rigid industries LED light bar from VP | Mike McLeod | Axial SCX-10 | 3 | 12-27-2012 01:33 AM |
