09-09-2013, 10:00 AM | #1 |
Newbie Join Date: Nov 2008 Location: Post Falls
| Rubbing woes after installing VP knuckles and C's
Hi all, does any body have any ideas what to do about my rubbing issue here? These are the Axial VWS wheels and I'm getting pretty bad rubbing after installing the VP knuckles and C's. Thanks in advance for any help! |
09-09-2013, 10:18 AM | #2 |
| Re: Rubbing woes after installing VP knuckles and C's
The stock whels don't work with VP steering components. You can try sanding the inside of the wheel a bit to get it to clear.
09-09-2013, 10:33 AM | #3 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
This is true stock axial wheels will not work. You need different rims or trim out the inside of the rim to clear.
09-09-2013, 11:07 AM | #4 |
| Re: Rubbing woes after installing VP knuckles and C's |
09-09-2013, 11:12 AM | #5 |
Just replacing a hex with another hex of the same width wont solve anything. Those would work great if he wanted to add width. Personally I want to keep it as narrow as possible.
09-09-2013, 11:29 AM | #6 |
RCC Addict Join Date: Mar 2009 Location: Chilton
wider wheel hexes. I think it is the traxxas slash hexes that fit and also there are some that rpphobby carries that a vendor on here makes. They need to be 8mm wide instead of the factory 5mm to clear. |
09-09-2013, 11:34 AM | #7 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
I had the same problem with my SCX10 Dingo when I did the VP stage one kit. Traxxas hexes fixed the problem.
09-09-2013, 11:40 AM | #8 |
You guys are F'n awesome! I'm gonna try the Traxxas hexes this week. Thanks for the quick and helpful replies everyone!
09-09-2013, 01:21 PM | #9 |
Thanks Nigels World! So, which ones should I get?
09-09-2013, 07:59 PM | #10 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Had all the same issues, on mine the +3mm worked (which is the same as a rustler/slash2wd front hex if you want to go that way) Hopefully you can just see the clearence at that right hand end on the drag link They'll work on the front but my stock Axial shafts are a whisker too short of thread on the rear, the nyloc nut won't lock on, so I've stayed with the stock hexs on the rear, unless your looking for it you don't notice. I'm not convinced theres enough thread on the front to run the 5mm but that might depend on what axles you have Axial/VP/etc Front wheel stub with +3mm hex rear wheel stub with stock Axial hex not enough thread left on either of those to go wider hexs Last edited by altd896; 09-09-2013 at 08:17 PM. Reason: Better pics |
09-09-2013, 08:44 PM | #11 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Just a side note.... I've done an XR mod to my SCX10 axles with VP 1.9 wheels...they rubbed so bad they rotated my knuckles and broke my axle housing Really twisted stuff up...so taking down the inside rings solved the problem....was a bit surprised a 1.9 wheel didn't fit on a wraith chub and knuckle....I've tried other wheels since then, they are close but don't rub.... |
09-10-2013, 03:53 PM | #12 |
| Re: Rubbing woes after installing VP knuckles and C's If you are running stock axles and wheels with no washers (I don't run washers since I think they promote the nut loosening up) you can run +5 in the front and +3 in the rear. EDIT: That's with universals. I don't have anything but universals here to measure. Maybe someone else with dog bones and a set of calipers can measure them for you. Last edited by Calderwood; 09-10-2013 at 04:00 PM. |
10-15-2013, 10:01 PM | #13 |
Newbie Join Date: Jun 2013 Location: Springfield
Do the wraith beadlocks rub on the stage 1 kit or is it the other glue on rim, or both?
10-16-2013, 05:41 AM | #14 |
Newbie Join Date: Aug 2013 Location: D town
Glue on rims rubbed on mine. I picked up some Integy wheels and the inner bead lock ring rubbed pretty bad. Changed to the Traxxas hexes like mentioned above and it cleared my STRC steering setup. I also ran into the wheel nuts not threading on afterwards. Swapped in a set of Axial universals and the outer shaft is longer than the factory dog bones and bolting on the wheel is no problem.
10-16-2013, 06:12 AM | #15 |
Newbie Join Date: Aug 2013 Location: Glenrock WY
10-16-2013, 07:22 AM | #16 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
to deal with clearance issues with my linkage there on my scx-10 I popped out the metal balls and cut the flanges off some plastic ones and popped them in. my linkage don't go off angles to much and didn't need the full range of movement. has been working pretty good for me.
09-04-2014, 08:07 AM | #17 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
what are the part numbers for those Traxxas hexes?
09-04-2014, 10:22 AM | #18 | |
| Re: Rubbing woes after installing VP knuckles and C's Quote:
09-04-2014, 11:28 PM | #19 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Rubbing woes after installing VP knuckles and C's - Similar Threads | ||||
Knuckles rubbing Beadlock screw?? | mcap | Axial SCX-10 | 7 | 10-06-2012 08:21 PM |
installing c hubs and knuckles | Lambo3244 | Axial AX-10 Scorpion | 3 | 08-10-2011 11:02 PM |
rubbing ....? | regal200021 | Axial AX-10 Scorpion | 9 | 10-19-2007 12:53 AM |
RPM Clawz rubbing on knuckles. | ccampb04 | Tamiya TLT Crawlers | 4 | 03-21-2005 03:18 PM |
