09-09-2013, 06:39 PM | #1 |
Pebble Pounder Join Date: Oct 2007 Location: Barnesville
| Spud-wrench wraith
Hey guys this my lil personal thread for my wraith it seems everyone else has one so why not Don't expect to see anything cool just yet I picked this up last week Posing on my tool box I'm following Harleys budget built but I'm limited to about 20.00 a week so this thread is going to be boring for a little while I did go ahead and do a few free mods such as relocating the battery up front Major improvement but I think the coolest part is I can do endo's now :what: I stripped my spur gear probably from this exact action lol. My first thing I plan to upgrade "if" I don't break anything else is the servo links the slop in the steering is driving me crazy Follow along will hope to have some VP goodies soon when I can save up sent from old rotary phone using tapatalk |
09-10-2013, 07:37 PM | #2 |
Took my wraith out again today man this thing is a blast :thumbup::thumbup: biggest issue I've found so far is it loves to be more on its backside then wheels down so I moved the shocks to lowest setting possible on the towers and softened the springs up just a lil bit. Not sure if anyone else was having issues with running into bumps and it just tipping over. I hate giving up some of the ground clearance. I already moved the battery up front but I may add 2.5 to each side of the front wheel to see if that helps. sent from old rotary phone using tapatalk |
09-11-2013, 05:31 AM | #3 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| Re: Spud-wrench wraith
Just keep in mind the Wraith is no speed demon. The hardest part for me was learning how to drive, I crossed over from nitro and it is a very different world driving a wraith.
09-11-2013, 07:17 AM | #4 | |
Newbie Join Date: Jul 2013 Location: Corvallis
| Re: Spud-wrench wraith Quote:
I had the same problem for the longest time. Then I Added a rear sway bar and Rock Beasts 2 w/ CI double deuce comp cut foams (2 stage foams)..... Made my wraith a ton more stable. Matt | |
09-11-2013, 07:23 AM | #5 |
Why don't you want to give up the clearance? I moved my shocks same as you, flipped my lower shock/link mounts and set up my shocks to be shorter than stock at ride height. Trust me, giving up the height and clearance of a stock Wraith will help you out in more ways than 1. I dropped mine an inch out if the box and have since done more.
09-11-2013, 09:41 AM | #6 | |
I wanted to take it out this morning and test it but just didn't have enough time. sent from old rotary phone using tapatalk | |
09-18-2013, 12:30 AM | #7 |
Was out bashing today and my servo is already showing signs of failure thought that was what my problem was today but got a little lucky. However I don't think ive ran it more than 10 times so I must be doing something right. I stripped the stock servo horn today ;D. I was going to order the robitronics servo horn but went with the Axial aluminum one instead I heard both were liked equally. So I will give it a try. Kind of curious to see what the next weakest link is. I would just go ahead and pull the servo as well but im doing a don't fix it till its broke build at least for now since I don't do any comps/trail runs just backyard fun Last edited by xsputnikx; 09-18-2013 at 12:32 AM. |
09-21-2013, 10:07 PM | #8 |
First upgrade I know its not much but its a small step :thumbup: sent from old rotary phone using tapatalk |
09-23-2013, 03:48 PM | #9 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
My servo went shortly after getting that same servo arm. I run a different servo now so its just sitting in my parts case. It's a good one as long as you keep it tight. I think if you are searching for a servo, get a Futaba so you can use your same servo arm.
09-23-2013, 04:11 PM | #10 |
09-23-2013, 04:21 PM | #11 | |
09-23-2013, 04:55 PM | #12 |
Newbie Join Date: Sep 2013 Location: Tacoma
if you replace the factory steering links than your servo will probably go out within a couple times of driving it. believe it or not all that slop is actually saving your servo. Watch Harleys video. he explains that.
09-23-2013, 05:25 PM | #13 |
The wraith likes going fast ;) Sweet build so far |
09-23-2013, 05:33 PM | #14 | |
I'm just trying to decide what I want to upgrade next .. I'm thinking the transmission gears to hot racing hardened steel sent from old rotary phone using tapatalk | |
11-02-2014, 11:12 AM | #15 |
Been a while since I've been on here my wraith has been sitting on the shelf with a broken front bumper. I am waiting on a replacement but went ahead and added some vp steering goodies to see how much quicker I can trash that servo. |
11-04-2014, 07:40 PM | #16 |
Rock Stacker Join Date: Aug 2014 Location: Mid TN
Get that thing back out on the trail! ;) I'm actually following a very similar philosophy in my WraithRunner build with a few exceptions. After I upgraded to a brushless motor, that "upgrade when it breaks" time gap has become much shorter. It seems like a never ending process. |
11-07-2014, 02:27 PM | #17 |
I need to but with limited funds I think I spend more time looking at my truck than actually driving it.
12-17-2014, 12:10 AM | #18 |
Some new shocks arrived today and I was quite impressed. Imo gmade has been one of the better quality shock sets I've purchased over the past 10 years. |
12-17-2014, 12:14 AM | #19 |
Added mamba max pro sct 3800kv combo along with 32p spur I forsee breaking something in my future ;) also picked up some VP links (still waiting on 2 uppers ) but here is how she sits at the moment while waiting for parts |
12-17-2014, 12:15 AM | #20 |
| Re: Spud-wrench wraith |
Spud-wrench wraith - Similar Threads | ||||
One spud in the buff | Mayhem Eng. | Chit Chat | 2 | 04-02-2012 11:55 AM |
Spud Run | 1rcmonster | Videos! | 0 | 08-28-2011 08:49 AM |
Any spud runners here? | djjiz | Non Crawler RC's | 6 | 09-30-2008 10:01 PM |
Spud Run | wrightcs77 | Chit Chat | 6 | 08-09-2007 12:35 PM |
another spud | microgoat | Tamiya TLT Crawlers | 19 | 11-07-2005 02:34 PM |
