09-15-2013, 01:41 PM | #1 |
Rock Crawler Join Date: Aug 2010 Location: Esko
| Wraith trans problems?
Can anyone tell me if this is a normal sound? I just installed a VP case, HR steel gears, Supershafty 6mm extended outputs,MIP driveshafts, and I regeared it to 15/87 with axial gears. It didn't make this noise before. I took it apart and all looks fine. It also does it when its coming to a stop. Nothing is rubbing anywhere. Is it just normal steel gear noise? http://youtu.be/J2E3sFZDtv4 Last edited by Tmaxxed; 09-15-2013 at 01:44 PM. |
09-15-2013, 01:47 PM | #2 |
| Re: Wraith trans problems?
My gears don't make that noise. It did make that noise when I had a missing tooth on my spur gear though. Another thing to look at is the pinion set screw. If it is hitting the spur gear it'll make that noise.
09-15-2013, 01:51 PM | #3 |
I checked the pinion setscrew and its not even close to the spur. Also if I'm spinning the tires by hand it only does it while turning them forward. No clicking if turning them backwards.
09-15-2013, 01:57 PM | #4 |
It's the gods punishing you for spending all that money on transmission parts and still running 48p.
09-15-2013, 01:59 PM | #5 |
32p gears are next on my list. My wallets just empty right now.
09-15-2013, 02:00 PM | #6 |
Pebble Pounder Join Date: Apr 2013 Location: CC
Mine sounded like that in the beginning because I chipped a spur tooth off. Then replaced all gears and such and now I have no noise. Steel gear noise sounds rough but smooth not the large clicking. Oh also I only have a slight clicking when reversing. Other than that it's all good. I would triple check everything. Sorry for no direct answer. |
09-15-2013, 02:08 PM | #7 |
I did put a different spur and pinion on and still the same noise. I guess I'll pull the trans apart again.
09-15-2013, 02:18 PM | #8 |
RCC Addict Join Date: Jun 2009 Location: Australia
Other place to check is in diffs front and rear. Mine made noise similar for a while. I installed the vp lockers and applied lock tight but not enough to one of the grub screws and one wound out. It rattled around in the casing of the diff and made a noise as it got caught up but only in one direction. Chewed teeth which didnt help. But gears in diff easy replace. Worth a look incase not in gear box. You can disconnect each diff too via drive shafts to prove if noise in gear box. Sent from my GT-I9300 using Tapatalk 2 |
09-15-2013, 02:22 PM | #9 | |
09-15-2013, 04:36 PM | #10 |
Newbie Join Date: Sep 2012 Location: atlanta
Did you get all the spacers put back in? I had a similar issue when I took my tranny apart and didn't see the small space between the motor plate and trans fell on the bench
09-15-2013, 05:06 PM | #11 |
| Yes its in there. I just thought of something though. My wraith trans has a plastic spacer in it and that's the one I used in my new ax/scx style VP trans case. All the scx10s I've had used a metal spacer. Could it be that it should have a metal spacer in it not the plastic?
09-16-2013, 02:32 PM | #12 |
Well, I took the whole transmisson apart today, there is nothing wrong with it. I took off one driveshaft, it still did it. I took off the other, still did it. I replaced the plastic spacer with a metal one, no change. The gears spin great, nothings rubbing anywhere. Maybe its the motor? But spinning the motor by hand it feels normal. If I spin it without the motor or driveshafts on it its nice and smooth. If the motor is on it I can hear the clicking. I'm at a loss. I guess I'm just going to run it like it is. Maybe I just need to drive it awhile and let every thing seat? It drives perfect. It just clicks. Any other ideas?
09-16-2013, 03:17 PM | #13 |
Newbie Join Date: Jul 2013 Location: Corvallis
Have you tried a different pinion and spur??? maybe toss the old ones back on and see if the noise goes away.
09-16-2013, 03:33 PM | #14 |
Yep, I tried that to. Same noise.
09-16-2013, 03:48 PM | #15 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Finally somebody that has the same noise mine had. I still have it a little but not as bad as it was. I took the trans back apart and cleaned every tooth of every gear using a small file and a knife. I was told that either the gear didn't get cut right or trash was in the grease and got smashed between the gears causing the the mesh to get a little off as they spin in the trans. Either way I never saw a issue but like I said it did get better after the file and knife deal.
09-16-2013, 03:50 PM | #16 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
Try checking the angle the pinion and spur are touching. I spent endless hours on the same thing in the wifes wraith just to find out it was a bent motor plate. It wasn't much but if the angles are changed the gear mesh will be off. I changed the plate and the noise was gone. Something to check
09-16-2013, 04:35 PM | #17 | |
09-16-2013, 04:36 PM | #18 | |
09-16-2013, 06:27 PM | #19 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
Could motor screws be too long? I think that happened to me once and I couldn't turn the motor.
09-16-2013, 06:39 PM | #20 | |
| Re: Wraith trans problems? Quote:
I actually have an armature that someone (not me) drove a motor mount screw right into the windings. | |
Wraith trans problems? - Similar Threads | ||||
wraith trans vs ax10 trans weight? | TLTCrawlin | Axial Wraith | 0 | 09-06-2012 07:14 PM |
Trans flip motor problems | trailreadyklr | Losi Mini-Rock Crawler | 11 | 01-07-2009 11:49 AM |
