Thread: Pinion and Spur shaft size question
Old 10-10-2013, 05:32 AM   #1
Default Pinion and Spur shaft size question
I am upgrading to a 32p 56/14 also buying a 32p 60/15 to test that out. I like the idea of going to metal. Would that be strongly recommended?
What is the pinion and spur shaft size I need to work with a Holmes 13t CrawlMaster in a Wraith?
Any recommended sites to purchase these from?
Thanks
2Crawl is offline   Reply With Quote
Old 10-10-2013, 05:59 AM   #2
Default Re: Pinion and Spur shaft size question
Search?
56t spur dtxc9397
60t spur DTXC9396
You need an steel 1/8" pinion for your motor. I like associated.
Calderwood is offline   Reply With Quote
Old 10-10-2013, 07:16 AM   #3
Thank you.
So you don't think a steel spur is worth the money?
Spur are they they just universal for scale RC? No certain thickness required? I see it references a Key #16.
I do understand gearing quite well after being a cyclist/triathlete my whole life. I just don't understand what parts will works.
Old 10-10-2013, 07:21 AM   #4
Originally Posted by 2Crawl View Post
Thank you.
A steel spur will be louder, heavier and you won't have any issues with a plastic 32p spur. Not all spurs will bolt up but both of the part numbers that I posted will work.
Old 10-10-2013, 07:07 PM   #5
I'll tell you right now your going to want s different ratio. 4:1 isn't low enough and both options you just listed give you 4:1. Pick something more in the range of 56/10-12, that way you won't smoke your new HH motor right off the bat. As for the steel spur, they are great, but chances are a plastic 1 will work just fine for your application.
crawler nut is offline   Reply With Quote
Old 10-11-2013, 05:03 AM   #6
I am glad you saw that and posted. You are absolutely right. I don't know what I was thinking when I posted that. Apparently I was not thinking.
Old 10-12-2013, 01:43 PM   #7
Well you know how hard I looked to find a 32p 10t, 11t pinion
I found them Here but only after converting 1/8 to 3.17mm using this conversion chart.
I wonder if these manufactured in Taiwan pinions are any good?
Old 10-12-2013, 04:56 PM   #8
A Robinson Racing pinion is $3 from rpphobby.
Pinion and Spur shaft size question - Similar Threads
AX2 gearbox. 60T,32p spur. 55turn. Max pinion size? Axa General Crawlers 0 09-05-2013 05:53 AM
Pinion and Spur question? Ffnye79 Axial SCX-10 4 10-26-2012 02:04 PM
pinion and spur gear size jcolvin General Crawlers 1 04-25-2012 10:13 AM
Novak Mongoose 380 Pinion shaft Size?? skullking Electronics 9 07-12-2011 06:19 PM
Pinion or Spur Question BMFOTP General Crawlers 6 04-17-2009 06:02 AM
